Does the UltraTivo3 plug-in work with the newer Tivo Bolt?
UltraTivo3 and Tivo Bolt
I don't have a TiVo Bolt, so I cannot confirm. If the TiVo Bolt supports the TiVo Remote Control Protocol and the TiVo Connect Automatic Machine Discovery Protocol Specification then it should work.
http://www.tivo.com/assets/images/ab...l_Protocol.pdf
I'll post a question on the TiVo forum to confirm.
Regards,
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
DVR not found
I've been able to see the two Tivo Minis through Homeseer. But the Tivo Bolt DVR does not show up.
On the Bolt I have set Network Remote Control to "Allow." (I'm assuming they changed it from Enable to Allow.)
I've logged in online to my Tivo account and I can't find any place where there are options for TiVo Remote Control Protocol and the TiVo Connect Automatic Machine Discovery Protocol Specification.
Any suggestions on how to get it to see the Bolt DVR?
(Sorry for not responding earlier, I had surgery on my neck and am just getting back on me feet now.)
TiVo Bolt with UltraTivo3
Hello,
I have been trying to get my Bolt to be seen by UltraTivo3, but it will not show up. I have tried removing and adding UltraTivo, and my Roamio+ shows up but not the Bolt.
In looking at the UltraTivo info screen, it specifically says that only Premier, Roamio and Mini are supported...
Further analysis on the traffic to/from the Roamio on a packet capture shows it beaconing as tcd/Series5. I beleive the bolt is tcd/Series6 and is not supported/detected by the UltraTivo3. Since I paid good money ($40 for any plugin is quite steep making Homeseer not a cheap solution for highly integrated environments) for the UltraTivo3, can we get this updated to support the new Tivo Bolt so that us 4Kers can retain our nice integration/automation with Tivo devices?
Regards,
Chris
Telnet Response
Originally posted by Ultrajones View PostFor anyone with a bolt, can you try to telnet to the TiVo bolt's IP address on 31339 to see if you get connected and can see data?
CH_STATUS 1041 LOCAL
That is all.
Tivo network advertisement
Originally posted by Ultrajones View PostAre you seeing the bolt advertise itself on the network?
will try to telnet now on 31339 and post what I see..
Chris
telnet 31339 results
CH_STATUS 0600 LOCAL
it eventually times out and says
COMMAND_TIMEOUTLOCAL
Chris
