Cannot communicate with the receiver RX-A2060
  • Cannot communicate with the receiver RX-A2060
    Hi there,
    Current Date/Time: 27/06/2017 20:32:10
    HomeSeer Version: HS3 Pro Edition 3.0.0.318
    System Uptime: 0 Days 20 Hours 7 Minutes 42 Seconds
    IP Address: 192.168.88.2
    Number of Devices: 584
    Number of Events: 10
    Available Threads: 400
    Enabled Plug-Ins
    3.0.0.68: HSTouch Server
    3.1.6373.35156: Yamaha
    3.0.1.130: Z-Wave
    I am trying to connect my RX-A2060 without any success. I have tried several models but nothing seems to work. I have also tried port 50000 and 80.
    Is my A2060 a different product family from the available amps?
    Is there anything I need to enable on the amp?
    Currently I can see the amp's web interface via browser and it works just fine.
    Thanks in advance,
    Michael
    You should be able to select the RS-A2030 for your model in the list available, as the 2060 is an updated version of that product family.
    Port 50000 is definitely the correct port rather than port 80
    Can you do the following.
    Go to the plugin config page and and enable "debug" logging and post the section of your HS3 log file that shows the plugin trying to connect to your amplifier please?
    That way I can get an idea of where things are failing.
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      Debug Log
      2017-06-28 12:03:34.1005|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:03:34.1321|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |tabs=tabDevices
      2017-06-28 12:03:34.1556|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=tabDevices
      2017-06-28 12:03:34.2177|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:03:34.2317|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getModels
      2017-06-28 12:03:34.2688|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:03:34.2823|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getFlags
      2017-06-28 12:03:45.1320|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:04:08.1498|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:04:24.8826|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:04:24.9001|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |action=create
      2017-06-28 12:04:24.9177|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][name]=Yamaha Amplifier
      2017-06-28 12:04:24.9397|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][modelid]=6
      2017-06-28 12:04:24.9612|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][ipaddress]=192.168.88.5
      2017-06-28 12:04:24.9808|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][ipport]=50000
      2017-06-28 12:04:25.0008|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][enabled]=Yes
      2017-06-28 12:04:25.0173|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][hsdeviceref]=
      2017-06-28 12:04:25.0368|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][model]=
      2017-06-28 12:04:25.0559|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |data[0][features]=
      2017-06-28 12:04:25.0724|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |editor_action=yamaha-amps-create
      2017-06-28 12:04:25.0919|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |Calling add/update validation procedure to add an amplifier
      2017-06-28 12:04:25.2903|INFO|HSPI_YAMAHA.WebConfig.AddNewAmplifier |Updated 1 record(d) of 1
      2017-06-28 12:04:25.3353|DEBUG|HSPI_YAMAHA.WebConfig.AddDataTableRow |{ "DT_RowId": 63,
      "name": "Yamaha Amplifier",
      "model": "RX-A2030",
      "ipaddress": "192.168.88.5",
      "ipport": "50000",
      "enabled": "Yes",
      "features": "",
      "hsdeviceref": "0",
      "modelid": 6
      2017-06-28 12:04:25.3874|WARN|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Device found in database but not in Homeseer - attempting to re-create the devices for Yamaha Amplifier
      2017-06-28 12:04:25.4105|INFO|HSPI_YAMAHA.HSPI.CreateNewAmplifierDevice |Creating root device for amplifier Yamaha Amplifier
      2017-06-28 12:04:25.5547|INFO|HSPI_YAMAHA.HSPI.CreateNewAmplifierDevice |Created an Amplifier root device with reference 1146
      2017-06-28 12:04:30.4832|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1146, Name:Yamaha Amplifier]
      2017-06-28 12:04:30.5849|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
      2017-06-28 12:04:30.6690|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:PWR child device with reference 1147
      2017-06-28 12:04:30.8508|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Standby
      2017-06-28 12:04:30.8728|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter On
      2017-06-28 12:04:30.8954|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter On/Standby
      2017-06-28 12:04:31.3131|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:04:31.3591|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:SLEEP child device with reference 1148
      2017-06-28 12:04:31.4177|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Off
      2017-06-28 12:04:31.4373|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 30 min
      2017-06-28 12:04:31.4628|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 60 min
      2017-06-28 12:04:31.4858|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 90 min
      2017-06-28 12:04:31.5154|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 120 min
      2017-06-28 12:04:31.5459|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Last
      2017-06-28 12:04:32.0262|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:VOL child device with reference 1149
      2017-06-28 12:04:32.0963|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Down
      2017-06-28 12:04:32.1169|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Up
      2017-06-28 12:04:32.1339|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Down 1 dB
      2017-06-28 12:04:32.1534|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Up 1 dB
      2017-06-28 12:04:32.1750|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Down 2 dB
      2017-06-28 12:04:32.1925|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Up 2 dB
      2017-06-28 12:04:32.2125|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Down 5 dB
      2017-06-28 12:04:32.2300|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Up 5 dB
      2017-06-28 12:04:32.2511|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter NumberRange
      2017-06-28 12:04:32.7759|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:MUTE child device with reference 1150
      2017-06-28 12:04:32.8310|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Off
      2017-06-28 12:04:32.8511|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Att -40 dB
      2017-06-28 12:04:32.8701|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Att -20 dB
      2017-06-28 12:04:32.8991|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter On
      2017-06-28 12:04:32.9247|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter On/Off
      2017-06-28 12:04:33.3819|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:INP child device with reference 1151
      2017-06-28 12:04:33.4345|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter TUNER
      2017-06-28 12:04:33.4661|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter MULTI CH
      2017-06-28 12:04:33.4996|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter PHONO
      2017-06-28 12:04:33.5587|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV1
      2017-06-28 12:04:33.5973|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV2
      2017-06-28 12:04:33.6193|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV3
      2017-06-28 12:04:33.6418|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV4
      2017-06-28 12:04:33.6649|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV5
      2017-06-28 12:04:33.6854|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV6
      2017-06-28 12:04:33.7034|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AV7
      2017-06-28 12:04:33.7250|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter V-AUX
      2017-06-28 12:04:33.7821|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AUDIO1
      2017-06-28 12:04:33.8006|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AUDIO2
      2017-06-28 12:04:33.8256|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AUDIO3
      2017-06-28 12:04:33.8467|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AUDIO4
      2017-06-28 12:04:33.8652|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter NET
      2017-06-28 12:04:33.8857|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Rhapsody
      2017-06-28 12:04:33.9053|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter SiriusXM
      2017-06-28 12:04:33.9323|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Pandora
      2017-06-28 12:04:33.9538|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter SERVER
      2017-06-28 12:04:33.9729|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter NET RADIO
      2017-06-28 12:04:33.9934|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter USB
      2017-06-28 12:04:34.0144|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter iPod (USB)
      2017-06-28 12:04:34.0355|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter AirPlay
      2017-06-28 12:04:34.6309|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:SOUNDPRG child device with reference 1152
      2017-06-28 12:04:34.7366|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Hall in Munich
      2017-06-28 12:04:34.7827|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Hall in Vienna
      2017-06-28 12:04:34.8033|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Hall in Amsterdam
      2017-06-28 12:04:34.8253|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Church in Freiburg
      2017-06-28 12:04:34.8438|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Church in Royaumont
      2017-06-28 12:04:34.8654|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Chamber
      2017-06-28 12:04:34.8894|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Village Vanguard
      2017-06-28 12:04:34.9265|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Warehouse Loft
      2017-06-28 12:04:34.9495|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Cellar Club
      2017-06-28 12:04:34.9750|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter The Roxy Theatre
      2017-06-28 12:04:34.9976|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter The Bottom Line
      2017-06-28 12:04:35.0196|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Sports
      2017-06-28 12:04:35.0532|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Action Game
      2017-06-28 12:04:35.0923|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Roleplaying Game
      2017-06-28 12:04:35.1128|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Music Video
      2017-06-28 12:04:35.1363|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Recital/Opera
      2017-06-28 12:04:35.1684|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Standard
      2017-06-28 12:04:35.1999|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Spectacle
      2017-06-28 12:04:35.2195|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Sci-Fi
      2017-06-28 12:04:35.2505|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Adventure
      2017-06-28 12:04:35.2741|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Drama
      2017-06-28 12:04:35.2961|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Mono Movie
      2017-06-28 12:04:35.3161|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 2ch Stereo
      2017-06-28 12:04:35.3392|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter 9ch Stereo
      2017-06-28 12:04:35.3677|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Surround Decoder
      2017-06-28 12:04:36.0062|INFO|HSPI_YAMAHA.HSPI.CreateNewGenericChildDev ice|Created a MAIN:PLAYBACK child device with reference 1153
      2017-06-28 12:04:36.0643|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Stop
      2017-06-28 12:04:36.0814|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Pause
      2017-06-28 12:04:36.1029|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Play
      2017-06-28 12:04:36.1254|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Skip Rev
      2017-06-28 12:04:36.1430|DEBUG|HSPI_YAMAHA.HSPI.CreateNewGenericChildDe vice|Adding parameter Skip Fwd
      2017-06-28 12:04:36.6187|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
      2017-06-28 12:04:36.6443|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:04:36.7274|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:04:54.1468|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:04:59.7269|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:05:17.1518|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:05:22.7294|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:05:40.1658|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:05:45.7414|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:05:54.2452|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
      2017-06-28 12:05:54.2698|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
      2017-06-28 12:05:54.3254|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:05:54.3429|ERROR|HSPI_YAMAHA.HSPI+AmpConfig.Enable |System.ArgumentException: The delegate must have only one target.
      at YamahaRemote.EventDrivenTCPClient.delConnectionStatusChanged .BeginInvoke(EventDrivenTCPClient sender, ConnectionStatus status, AsyncCallback callback, Object object)
      at YamahaRemote.EventDrivenTCPClient.set_ConnectionState(Connec tionStatus value)
      at YamahaRemote.EventDrivenTCPClient.Connect()
      at YamahaRemote.Remote.Connect()
      at HSPI_YAMAHA.HSPI.AmpConfig.Connect()
      at HSPI_YAMAHA.HSPI.AmpConfig.Initialise()
      at HSPI_YAMAHA.HSPI.AmpConfig.Enable()
      2017-06-28 12:06:03.1647|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:06:13.4325|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 4
      2017-06-28 12:06:13.4765|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 4
      2017-06-28 12:06:13.6213|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Disconnect |Disconnected from Yamaha Yamaha Amplifier.
      2017-06-28 12:06:17.2071|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
      2017-06-28 12:06:17.2562|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
      2017-06-28 12:06:17.3599|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:06:17.4430|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:06:26.1652|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for (Not Found=1138): DisconnectedByHost
      2017-06-28 12:06:26.7842|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1149 command : 18138
      2017-06-28 12:06:26.8618|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |[OUT][Yamaha Yamaha Amplifier]: @MAIN:VOL=Up 5 dB
      2017-06-28 12:06:28.1740|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1149 command : 18138
      2017-06-28 12:06:28.2506|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |[OUT][Yamaha Yamaha Amplifier]: @MAIN:VOL=Up 5 dB
      2017-06-28 12:06:49.5524|DEBUG|HSPI_YAMAHA.HSPI.InitIO |Completed InitIO
      2017-06-28 12:06:58.7063|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1146, Name:Yamaha Amplifier]
      2017-06-28 12:06:59.7360|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
      2017-06-28 12:06:59.9293|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
      2017-06-28 12:06:59.9508|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:07:00.0235|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:07:08.1438|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1151 command : 18155
      2017-06-28 12:07:08.2535|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |[OUT][Yamaha Yamaha Amplifier]: @MAIN:INP=AV1
      2017-06-28 12:07:23.0397|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:07:46.0428|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:08:09.0399|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:08:32.0470|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:08:32.8248|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
      2017-06-28 12:08:32.8743|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
      2017-06-28 12:08:32.9419|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:08:32.9645|ERROR|HSPI_YAMAHA.HSPI+AmpConfig.Enable |System.ArgumentException: The delegate must have only one target.
      2017-06-28 12:08:43.8757|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:08:43.9043|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getModels
      2017-06-28 12:08:44.0911|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:08:44.1196|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getFlags
      2017-06-28 12:08:48.6415|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:08:48.6861|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |tabs=tabDevices
      2017-06-28 12:08:48.7031|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=tabDevices
      2017-06-28 12:08:48.8048|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:08:48.8198|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getModels
      2017-06-28 12:08:48.8639|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:08:48.8639|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getFlags
      2017-06-28 12:09:06.5844|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
      2017-06-28 12:09:06.6249|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |tabs=tabConfig
      2017-06-28 12:09:06.6991|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=tabConfig
      2017-06-28 12:09:53.1964|DEBUG|HSPI_YAMAHA.HSPI.InitIO |Completed InitIO
      2017-06-28 12:10:04.1397|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1146, Name:Yamaha Amplifier]
      2017-06-28 12:10:05.5885|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
      2017-06-28 12:10:05.7769|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
      2017-06-28 12:10:05.7989|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:10:05.8865|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:10:28.8981|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:10:51.9124|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:11:14.9126|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:11:37.9132|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:12:00.9144|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:12:23.9305|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
      2017-06-28 12:12:29.0565|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
      2017-06-28 12:12:29.0795|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
      2017-06-28 12:12:29.1437|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
      2017-06-28 12:12:29.1667|ERROR|HSPI_YAMAHA.HSPI+AmpConfig.Enable |System.ArgumentException: The delegate must have only one target.
        There's a new version in the updater that addresses a few issues. Firstly, we should no longer see the The delegate must have only one target. error.
        Secondly, it looks like your Amp automatically disconnects the plugin ever 23 seconds. The docs suggest this is every 30 seconds, so I've reduced the keepalive interval.
        Can you give the latest version a try and see if you have more joy?
          Still having issues. New debug log
          Hi,
          I have updated the plugin but i still receive the same error as before. I have also restarted homeseer just in case.
          ----------------- Logging started on 2017-06-28 19:22:50.4305 ------------------
          2017-06-28 19:22:50.4090|DEBUG|HSPI_YAMAHA.HSPI.InitIO |Completed InitIO
          2017-06-28 19:23:03.1860|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1146, Name:Yamaha Amplifier]
          2017-06-28 19:23:06.1242|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
          2017-06-28 19:23:06.5279|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
          2017-06-28 19:23:06.5875|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
          2017-06-28 19:23:06.6887|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:23:26.9052|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
          2017-06-28 19:23:26.9277|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
          2017-06-28 19:23:26.9963|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
          2017-06-28 19:23:27.0153|ERROR|HSPI_YAMAHA.HSPI+AmpConfig.Enable |System.ArgumentException: The delegate must have only one target.
          2017-06-28 19:24:21.5647|DEBUG|HSPI_YAMAHA.HSPI.InitIO |Completed InitIO
          2017-06-28 19:24:31.5885|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1146, Name:Yamaha Amplifier]
          2017-06-28 19:24:32.5946|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
          2017-06-28 19:24:32.7619|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
          2017-06-28 19:24:32.7859|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
          2017-06-28 19:24:32.8575|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:24:55.8736|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:25:18.8706|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:25:27.8067|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 4
          2017-06-28 19:25:27.8232|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 4
          2017-06-28 19:25:28.3225|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Disconnect |Disconnected from Yamaha Yamaha Amplifier.
          2017-06-28 19:25:32.9131|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |SetIOMulti: Received CAPI for 1146 command : 5
          2017-06-28 19:25:32.9476|DEBUG|HSPI_YAMAHA.HSPI.SetIOMulti |Root control received : 5
          2017-06-28 19:25:33.0423|INFO|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Connecting to Yamaha Yamaha Amplifier
          2017-06-28 19:25:33.1209|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:25:40.1629|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
          2017-06-28 19:25:40.1799|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getModels
          2017-06-28 19:25:40.3171|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
          2017-06-28 19:25:40.3342|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getFlags
          2017-06-28 19:25:41.8707|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:25:43.3416|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
          2017-06-28 19:25:43.3626|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |tabs=tabDevices
          2017-06-28 19:25:43.3791|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=tabDevices
          2017-06-28 19:25:43.4773|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
          2017-06-28 19:25:43.4938|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getModels
          2017-06-28 19:25:43.5344|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |postBackProc data:
          2017-06-28 19:25:43.5474|DEBUG|HSPI_YAMAHA.WebConfig.postBackProc |id=getFlags
          2017-06-28 19:25:56.1239|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:26:04.8742|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:26:19.1390|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:26:27.8888|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:26:42.1397|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:26:50.8909|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
          2017-06-28 19:27:05.1527|INFO|HSPI_YAMAHA.HSPI+AmpConfig.HandleUpdateCo nnectionEvent|Connection status for Yamaha Yamaha Amplifier: DisconnectedByHost
            Thanks for this detail, it highlighted a major bug. The new version in the updater should fare a lot better.
              IT WORKS!!
              Thank you so much for the support. The plugin finally works!!!
