Auto Disable?
  • Auto Disable?
    The plugin is working again. Thanks. However when I edit the amplifier, check enabled, save the yamaha plugin page loads and says 'enabled', but upon refresh the yamaha plugin page says 'disabled'. Ive tried enabling a few times, but am having the same experience. Thanks in advance for any help.
    I can connect to my amp via web browser
    So i know the IP is good, however I am not sure about the port, so I left the default of 5000 in the field. Thanks again
      It is an RX-V3900
      I picked the RX-V1075 from the dropdown menu
        RX-V3900
        Has 3 Zones. I think the other profiles I tried from the drop down menu may have 2 zones.
          Hi ebendj I'm not sure of the issue you're reporting here? Are you saying that you're not seeing devices created for the 3 zones o your amplifier?
          What model is your amp?
          Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
