Problem installing
  • Problem installing
    I had the older Agwan Yamaha plugin and tried removing and replacing with the trial of this newer plugin. Just getting the below now. Looks like I may have removed what I thought was an orphaned older device. I've tried disabling, removing, and reinstalled the plugin a couple times with no change. Any suggestions? (I get a 404 error when I try to go to the plugin amp config)
    Nov-21 11:25:01 Info Plugin Yamaha with instance: has disconnected
    Nov-21 11:24:58 Yamaha Error Error Initialising amplifiers: The given key was not present in the dictionary.
    Nov-21 11:24:58 Yamaha Warning This amplifier has been removed from the database. Removing it from HomeSeer
    Nov-21 11:24:50 Starting Plug-In Plugin Yamaha started successfully in 183 milliseconds
    Nov-21 11:24:50 Starting Plug-In Initializing plugin Yamaha ...
    Nov-21 11:24:50 Starting Plug-In Yamaha loaded in 15029 milliseconds
    Nov-21 11:24:35 Info Plugin Yamaha has connected. IP:127.0.0.1:64646
    Nov-21 11:24:35 Warning I/O interface Yamaha is down, executable is not running, restarting ...
    Nov-21 11:24:17 Info Plugin Yamaha with instance: has disconnected
    Nov-21 11:24:14 Yamaha Error Error Initialising amplifiers: The given key was not present in the dictionary.
    Nov-21 11:24:14 Yamaha Warning This amplifier has been removed from the database. Removing it from HomeSeer
    NEVERMIND....TRIED REINSTALLING SEVERAL TIMES AND FINALLY APPARENTLY GOT IT WORKING.
