I had the older Agwan Yamaha plugin and tried removing and replacing with the trial of this newer plugin. Just getting the below now. Looks like I may have removed what I thought was an orphaned older device. I've tried disabling, removing, and reinstalled the plugin a couple times with no change. Any suggestions? (I get a 404 error when I try to go to the plugin amp config)
NEVERMIND....TRIED REINSTALLING SEVERAL TIMES AND FINALLY APPARENTLY GOT IT WORKING.
Nov-21 11:25:01 | Info | Plugin Yamaha with instance: has disconnected |
Nov-21 11:24:58 | Yamaha Error | Error Initialising amplifiers: The given key was not present in the dictionary. |
Nov-21 11:24:58 | Yamaha Warning | This amplifier has been removed from the database. Removing it from HomeSeer |
Nov-21 11:24:50 | Starting Plug-In | Plugin Yamaha started successfully in 183 milliseconds |
Nov-21 11:24:50 | Starting Plug-In | Initializing plugin Yamaha ... |
Nov-21 11:24:50 | Starting Plug-In | Yamaha loaded in 15029 milliseconds |
Nov-21 11:24:35 | Info | Plugin Yamaha has connected. IP:127.0.0.1:64646 |
Nov-21 11:24:35 | Warning | I/O interface Yamaha is down, executable is not running, restarting ... |
Nov-21 11:24:17 | Info | Plugin Yamaha with instance: has disconnected |
Nov-21 11:24:14 | Yamaha Error | Error Initialising amplifiers: The given key was not present in the dictionary. |
Nov-21 11:24:14 | Yamaha Warning | This amplifier has been removed from the database. Removing it from HomeSeer |
