Hi,
I have a Yamaha RX-A1050 and am using the plugin (v3.3.6389.22764) . I noticed a while ago that the plugin says that the amplifier is disabled. I spent a bit of time disabling and enabling the pulgin, checking logs etc. But I can't seem to fix this problem. The plugin just says the amp in not enabled.
I ran a debug log:
2018-11-29 08:43:37.3237|DEBUG|HSPI_YAMAHA.HSPI.InitIO |Completed InitIO
2018-11-29 08:43:40.8666|DEBUG|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmp lifiers|Found an Amplifier, [Ref:1980, Name:Yamaha Amplifier]
2018-11-29 08:43:41.1315|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 28 new/existing functions to validate
2018-11-29 08:43:41.1635|DEBUG|HSPI_YAMAHA.HSPI.CreateChildDevices |Got 17 new/existing functions to validate
2018-11-29 08:43:41.1874|INFO|HSPI_YAMAHA.HSPI.FindCreateInitialiseAmpl ifiers|Found 1 amplifier(s) to initialise.
2018-11-29 08:43:41.1874|WARN|HSPI_YAMAHA.HSPI+AmpConfig.Initialise |Not establishing a connection to Yamaha Living Room Yamaha Amplifier - amplifier is disabled
Is there something simple I am missing? Has something changed since updating HS (HS3 Pro Edition 3.0.0.478 (Windows))?
I did update the firmware on the amp a while ago, but am not sure if this is about the time the problem started.
Any help[ on how to fix this would be helpful.
Thanks, Marty.
I ran a debug log:
Thanks, Marty.
