MSVCR71.dil
  • MSVCR71.dil
    Hi Bob, not sure if this is a problem associated with BLNinja, but it is the one plugin I cannot get working.
    had a major crash on the HS computer, re-build was a nightmare - HS registration problems. However got it basically working except for BLNinja. on starting up HS I get an error immediately after BLNinja has activated, cannot find MSVCR71.dll and all stops.
    Any ideas?
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    I do not install that file at all with BLNinjaControl.
    I did look up the file and here is the description of it:
    msvcr71.dll is a module containing standard C library functions such as printf, memcpy, and cos. It is a part of the Microsoft C Runtime Library.
    Perhaps someone who uses this could check if they have this dll.
    Cheers,
    Bob
      Thanks for the quick reply Bob.
      I have just searched the file on Google and it appears it may be a .net file associated with Windows media Player, although why it should bring HS to a halt is beyond me.
      Thanks again.
        Gogs, just google for it and download it, once you have it on your pc copy it to C:/windows/system32
        TrOjAn
          Terry, thanks, but a repair on NET solved that problem, but not BLNija.
          Downloaded latest from the HS Updater, and it did work (The Updater that is), but HS reports cannot find CM19A?
          Don't realy know where to go from here.
            Are you using a 64bit system?
            I am not sure the cm19A driver will work on a 64bit system. I know it works on XP and XP Pro.
            I do not run the plugin anymore but it worked on XP with no issues.
            Cheers,
            Bob
              Nope not 64. Here is a selection of the HS startup log. Note the CM19 bits.
              26/03/2010 19:05:31 ~!~BLNinjaControl start~!~BLNinjaControl version is: 1.0.21.0
              26/03/2010 19:05:31 ~!~Plug-In~!~Initializing Plug-in: BLNinjaControl
              26/03/2010 19:05:31 ~!~BLNinjaControl start~!~Initializing BLNinjaControl...
              26/03/2010 19:05:31 ~!~BLNinjaControl start~!~Loaded configuration successfully
              26/03/2010 19:05:31 ~!~BLNinjaControl start~!~Debug logging is Enabled!
              26/03/2010 19:05:31 ~!~BLNinjaControl start~!~Registering files for BLNinjaControl... Please wait -- This should take approx 30 seconds
              26/03/2010 19:05:34 ~!~BLNinjaControl start~!~Registration complete
              26/03/2010 19:05:34 ~!~BLNinjaControl start~!~Searching for CM19A USB device...
              26/03/2010 19:05:34 ~!~BLNinjaControl start~!~CM19A USB device was detected on the system!
              26/03/2010 19:05:35 ~!~BLNinjaControl start~!~BLNinjaControl plugin has been initialized
              26/03/2010 19:05:35 ~!~Plug-In~!~Finished initializing plug-in BLNinjaControl
              26/03/2010 19:05:35 ~!~Warning~!~Interface DooMotion is running as a trial, 7 days remaining.
              26/03/2010 19:05:35 ~!~Plug-In~!~Initializing Plug-in: DooMotion
              26/03/2010 19:05:35 ~!~BLNinjaControl Info~!~CM19A USB device has been re-connected to the system. Ninja control is now enabled!
              26/03/2010 19:05:36 ~!~Plug-In~!~Finished initializing plug-in DooMotion
              26/03/2010 19:05:36 ~!~BLBackup start~!~Register Callback completed
              26/03/2010 19:05:36 ~!~BLBackup start~!~BLBackup version is: 1.0.19.0
              26/03/2010 19:05:36 ~!~Plug-In~!~Initializing Plug-in: BLBackup
              26/03/2010 19:05:36 ~!~BLBackup start~!~Initializing BLBackup...
              26/03/2010 19:05:36 ~!~BLBackup start~!~Loaded configuration successfully
              26/03/2010 19:05:36 ~!~BLBackup start~!~Backup Folders have been loaded.
              26/03/2010 19:05:36 ~!~BLBackup start~!~BLBackup plugin has been initialized
              26/03/2010 19:05:36 ~!~Plug-In~!~Finished initializing plug-in BLBackup
              26/03/2010 19:05:36 ~!~Warning~!~Interface AC-RF2 Processor is running as a trial, 7 days remaining.
              26/03/2010 19:05:36 ~!~AC-RF2 Processor~!~AC-RF2 Processor Plugin Version Release 1.1.3226.27426 Has Registered. Plugin Copyright (c) 2008 - AutomationCraft, LLC.
              26/03/2010 19:05:36 ~!~Plug-In~!~Initializing Plug-in: AC-RF2 Processor
              26/03/2010 19:05:38 ~!~Warning~!~'status' property on device ACRF2 Plugin ACRF2 Device Monitor was accessed - this property has been deprecated and should not be used.
              26/03/2010 19:05:39 ~!~Plug-In~!~Finished initializing plug-in AC-RF2 Processor
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Register callback completed
              26/03/2010 19:05:39 ~!~Plug-In~!~Initializing Plug-in: HSTouch Server
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for STATUS CHANGE callback.
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for STRING CHANGE callback.
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for CONFIG CHANGE callback.
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for CALLER-ID callback.
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for VALUE CHANGE callback.
              26/03/2010 19:05:39 ~!~HSTouch Server~!~Registered for GENERIC EVENT callback.
              26/03/2010 19:05:39 ~!~Plug-In~!~Finished initializing plug-in HSTouch Server
              26/03/2010 19:05:39 ~!~Warning~!~Interface DooMenuBar is running as a trial, 7 days remaining.
              26/03/2010 19:05:39 ~!~Plug-In~!~Initializing Plug-in: DooMenuBar
              26/03/2010 19:05:39 ~!~DooMenuBar startup~!~Register callback completed
              26/03/2010 19:05:39 ~!~COM Plugin~!~Calling InitIO
              26/03/2010 19:05:39 ~!~COM Plugin Info~!~DooMenuBar Initializing...
              26/03/2010 19:05:39 ~!~DooMenuBar Info~!~DooMenuBar version is: 2.4.5beta
              26/03/2010 19:05:39 ~!~Plug-In~!~Finished initializing plug-in DooMenuBar
              26/03/2010 19:05:39 ~!~PHNetwork~!~Register callback completed
              26/03/2010 19:05:39 ~!~Plug-In~!~Initializing Plug-in: PHNetwork
              26/03/2010 19:05:41 ~!~PHNetwork~!~Plug-In is licensed
              26/03/2010 19:05:41 ~!~PHNetwork~!~Retrieved house code is ]
              26/03/2010 19:05:41 ~!~PHNetwork~!~Init Options called
              26/03/2010 19:05:41 ~!~PHNetwork~!~Init Options end
              26/03/2010 19:05:41 ~!~PHNetwork~!~PollDevices thread started
              26/03/2010 19:05:41 ~!~Plug-In~!~Finished initializing plug-in PHNetwork
              26/03/2010 19:05:41 ~!~Plug-In~!~Initializing Plug-in: X10 CM19A FireCracker USB
              26/03/2010 19:05:41 ~!~COM Plugin~!~Calling InitIO
              26/03/2010 19:05:41 ~!~CM19A_USB~!~CM19A USB Not Connected
              26/03/2010 19:05:41 ~!~COM Plugin Info~!~CM19A USB Not ConnectedPlease connect the device...
              26/03/2010 19:05:44 ~!~Warning~!~GetDevice is not reliable for device enumeration. Please use the new GetDeviceEnumerator method.
              26/03/2010 19:05:46 ~!~Plug-In~!~Finished initializing plug-in X10 CM19A FireCracker USB
              I note from reading the log that I still have licence problems.
                OK, it's getting better!
                I upgraded BLNija and BL Security from HS's upgrader. One small problem - I do not have the registration codes.
                The old cut and paste BL registration do not work if it's come out of HS.
                lord I knew Home Automation would be a chalange, but this much.
                  You do not need to use the X10 CM19A FireCracker USB plugin.
                  Re: licenses
                  Log a help desk ticket on my site and I will send them.
                  I sent emails to everyone that registered a plugin with me but if your email changed and you did not let me know then you would have likely not got the emails.
                  Cheers,
                  Bob
                    Re: licenses
                    My email has not changed from the day we met, Sir.
                      Well then your email blocked it. I sent the licenses to everyone.
                      Cheers,
                      Bob
