Blue Iris INFO:plugin start is pending
  • #16
    Ooops, neglected to mention I'm running on Linux (Ubuntu 16.04). Cannot get BI to initialize properly and have no control panel to set parameters. Checked HSPI_BI.ini to make sure that IP address and port for BI were correct.
    Error message is: WARNING: Failed getting InterfaceStatus from Blue-Iris - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    Not sure what to do in this situation... Presume I did something stupid, which is the usual cause of my distress.
    Rog
    • #17
      Rog
      Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      • #18
        My windows version is working fine with the latest HS, BI and BI Plugin versions. So maybe it is just the Linux version that's in trouble.
        • #19
          Starting HSPI_BI.exe from command line (HS3 V.368; V.435 to follow):
          root@Homeseer-Linux:/homeseer# mono ./HSPI_BI.exe
          Unhandled Exception:
          NLog.NLogConfigurationException: Error when setting property 'Format' on Layout Renderer: ${date} ---> System.ArgumentException: Object of type 'System.ReadOnlySpan`1[System.Char]' cannot be converted to type 'System.String'.
          at System.RuntimeType.CheckValue (System.Object value, System.Reflection.Binder binder, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00071] in <9bbab8f8a2a246e98480e70b0839fd67>:0
          at System.Reflection.MonoMethod.ConvertValues (System.Reflection.Binder binder, System.Object[] args, System.Reflection.ParameterInfo[] pinfo, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00069] in <9bbab8f8a2a246e98480e70b0839fd67>:0
          at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00011] in <9bbab8f8a2a246e98480e70b0839fd67>:0
          at System.Reflection.MonoProperty.SetValue (System.Object obj, System.Object value, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] index, System.Globalization.CultureInfo culture) [0x0005d] in <9bbab8f8a2a246e98480e70b0839fd67>:0
          at System.Reflection.PropertyInfo.SetValue (System.Object obj, System.Object value, System.Object[] index) [0x00000] in <9bbab8f8a2a246e98480e70b0839fd67>:0
          at NLog.Internal.PropertyHelper.SetPropertyFromString (System.Object obj, System.String propertyName, System.String value, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x000fe] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          --- End of inner exception stack trace ---
          at NLog.Internal.PropertyHelper.SetPropertyFromString (System.Object obj, System.String propertyName, System.String value, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x001b2] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.LayoutParser.ParseLayoutRenderer (NLog.Config.ConfigurationItemFactory configurationItemFactory, NLog.Internal.SimpleStringReader sr) [0x0019c] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.LayoutParser.CompileLayout (NLog.Config.ConfigurationItemFactory configurationItemFactory, NLog.Internal.SimpleStringReader sr, System.Boolean isNested, System.String& text) [0x0009a] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.SimpleLayout.set_Text (System.String value) [0x00024] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.SimpleLayout..ctor (System.String txt, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x0000d] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.Layout.FromString (System.String layoutText, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x00000] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.Layout.FromString (System.String layoutText) [0x00006] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at NLog.Layouts.Layout.op_Implicit (System.String text) [0x00000] in <fd2e12f56b8f44d0b24789be11b1a5ad>:0
          at HSPI_BI.MyLogConfig.ConfigConsoleTarget () [0x00000] in <0516aed35275490595d9181f7a1b4993>:0
          at HSPI_BI.MyLogConfig..ctor () [0x0009a] in <0516aed35275490595d9181f7a1b4993>:0
          at HSPI_BI.Main.Main () [0x00016] in <0516aed35275490595d9181f7a1b4993>:0
          • #20
            Starting HSPI_BI.exe from command line (HS3 v.435):
            root@Homeseer-Linux:/HomeSeer# mono ./HSPI_BI.exe
            [ERROR] FATAL UNHANDLED EXCEPTION: NLog.NLogConfigurationException: Error when setting property 'Format' on Layout Renderer: ${date} ---> System.ArgumentException: Object of type 'System.ReadOnlySpan`1[System.Char]' cannot be converted to type 'System.String'.
            • #21
              Both of those are running on Ubuntu 16.04
              • #22
                • #23
                  Yes, updated to latest mono when I installed v.435.
                  • #24
                    Can you grab 3.1.3.x from the updater and let me know if it addresses your issue please? I don't have a Linux test box handy but I think this should sort the issue out.
                    • #25
                      Works just fine in v.368 and v.435!!! Nicely done, and thank you for the fast response.
                      Rog
                      • #26
                        I can confirm my issue is Linux based
                        Sent from my iPhone using Tapatalk Pro
                        Steve
                        • #27
                          Did the update fix it?
