Saw this in the log and wanted to know if it is important for you to see.
Aug-25 11:10:34 AM | Blue-Iris Error | Error: Cannot deserialize the current JSON array (e.g. [1,2,3]) into type 'HSPI_BI.BlueIris+StatusData' because the type requires a JSON object (e.g. {"name":"value"}) to deserialize correctly. To fix this error either change the JSON to a JSON object (e.g. {"name":"value"}) or change the deserialized type to an array or a type that implements a collection interface (e.g. ICollection, IList) like List that can be deserialized from a JSON array. JsonArrayAttribute can also be added to the type to force it to deserialize from a JSON array. Path 'data', line 1, position 73. |
