Error in log
    Error in log
    Error: Unexpected character encountered while parsing number: ". Path 'data.lock', line 1, position 93.
    Michael
    Not sure this is coming from my plugin? Can you give me the log file lines before and after this?
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      Does this help?
      Nov-17 6:31:52 AM Z-Wave Znet: Z-Wave Wake-Up 'No More Info' Notification sent to Node 134(Root Office Motion Sensor 2 - Root).
      Nov-17 6:31:52 AM Z-Wave Znet: Wake-Up Notification Processing for Node 134 (Root Office Motion Sensor 2 - Root)
      Nov-17 6:31:52 AM SDJ-Health Wake-Up Device #833 added to message queue for processing.
      Nov-17 6:31:52 AM Z-Wave Znet: Z-Wave Wake-Up Notification Received for Node 134
      Nov-17 6:30:03 AM Blue-Iris Error Error: Unexpected character encountered while parsing number: ". Path 'data.lock', line 1, position 93.
      Nov-17 6:30:00 AM Event Event Trigger "Cameras Patio Motion Enable - Wind Speed"
      Nov-17 6:26:10 AM SDJ-Health 1 queued messages processed
      Michael
        OK, it's definitely coming form my plugin ;-) Looking into it.
          Also noticed these error messages in the log. I did just add some new cameras.
          And, I enable and disable cameras - could this be the Parameter count mismatch? I would prefer to hide/Unhide.
          Motion alerts are not firing in HS3.
          ----------------- Logging started on 2019-01-05 00:21:03.5695 ------------------
          2019-01-05 00:21:03.4985|INFO|HSPI_BI.web_config.postBackProc |Enabling logging to file: C:\Program Files (x86)\HomeSeer HS3\Logs\HSPI_BI.log
          2019-01-05 00:21:07.4066|ERROR|HSPI_BI.HSPI.PluginFunction |Error in PluginProc:Parameter count mismatch.
          System.Reflection.TargetParameterCountException: Parameter count mismatch.
          at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Obj ect obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
          at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
          at HSPI_BI.HSPI.PluginFunction(String proc, Object[] parms)
          2019-01-05 00:21:07.4066|ERROR|HSPI_BI.HSPI.PluginFunction |Procedure called: Alert
          2019-01-05 00:21:07.6166|INFO|HSPI_BI.plugin.CheckConfig |Connected to Blue Iris server Home as Homeseer - polling every 30 seconds
          2019-01-05 00:21:42.3373|INFO|HSPI_BI.BlueIris.MyLogin |Successfully logged in to BlueIris server: Home (ver 4.8.4.6) as Homeseer.
          ----------------- Logging finished on 2019-01-05 00:22:05.6718 -----------------
          Click image for larger version  Name:	24619409-3DF6-4367-9285-C8DB7266953D.png Views:	1 Size:	207.6 KB ID:	1272177
          Michael
            I was hoping for a response from beerygaz. None of my Alert events are working. Running BI 4.8.4.6.
            To troubleshoot, I downgraded version by version to 4.8.4.3 but still getting the same error.
            Any thiughts on on what I should do next?
            Michael
              Originally posted by Rvtravlr View Post
              Does this help?
              This looks like some strange data in the JSON payload being passed to me from Blue Iris, to get to the bottom of it I'm going to need you to turn on Debug logging, enable L"Log to file" and then when the error occurs again, mail me the HSPI_BI.LOG file in your HS# \Logs folder to gavin at highpeak.co.za
              I need to see exactly what data is coming back from BI.
              Regards
              Gavin
                I will do so.
                Michael
                Michael
