Error: Unexpected character encountered while parsing number: ". Path 'data.lock', line 1, position 93.
Error in log
Does this help?
Nov-17 6:31:52 AM Z-Wave Znet: Z-Wave Wake-Up 'No More Info' Notification sent to Node 134(Root Office Motion Sensor 2 - Root). Nov-17 6:31:52 AM Z-Wave Znet: Wake-Up Notification Processing for Node 134 (Root Office Motion Sensor 2 - Root) Nov-17 6:31:52 AM SDJ-Health Wake-Up Device #833 added to message queue for processing. Nov-17 6:31:52 AM Z-Wave Znet: Z-Wave Wake-Up Notification Received for Node 134 Nov-17 6:30:03 AM Blue-Iris Error Error: Unexpected character encountered while parsing number: ". Path 'data.lock', line 1, position 93. Nov-17 6:30:00 AM Event Event Trigger "Cameras Patio Motion Enable - Wind Speed" Nov-17 6:26:10 AM SDJ-Health 1 queued messages processed Michael
Also noticed these error messages in the log. I did just add some new cameras.
And, I enable and disable cameras - could this be the Parameter count mismatch? I would prefer to hide/Unhide.
Motion alerts are not firing in HS3.
----------------- Logging started on 2019-01-05 00:21:03.5695 ------------------
2019-01-05 00:21:03.4985|INFO|HSPI_BI.web_config.postBackProc |Enabling logging to file: C:\Program Files (x86)\HomeSeer HS3\Logs\HSPI_BI.log
2019-01-05 00:21:07.4066|ERROR|HSPI_BI.HSPI.PluginFunction |Error in PluginProc:Parameter count mismatch.
System.Reflection.TargetParameterCountException: Parameter count mismatch.
at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Obj ect obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at HSPI_BI.HSPI.PluginFunction(String proc, Object[] parms)
2019-01-05 00:21:07.4066|ERROR|HSPI_BI.HSPI.PluginFunction |Procedure called: Alert
2019-01-05 00:21:07.6166|INFO|HSPI_BI.plugin.CheckConfig |Connected to Blue Iris server Home as Homeseer - polling every 30 seconds
2019-01-05 00:21:42.3373|INFO|HSPI_BI.BlueIris.MyLogin |Successfully logged in to BlueIris server: Home (ver 4.8.4.6) as Homeseer.
----------------- Logging finished on 2019-01-05 00:22:05.6718 -----------------
Michael
I need to see exactly what data is coming back from BI.
Regards
GavinAuthor of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
