How to change Profiles in Blue Iris Plugin Actions
  • How to change Profiles in Blue Iris Plugin Actions
    Hello,
    I am trying to set up an event that changes the BI profile between Home(Profile 1) and Away(Profile 2). I've used the below event but am getting the error below:Click image for larger version  Name:	Untitled.png Views:	1 Size:	6.9 KB ID:	1282387
    eb-04 4:27:32 PM Blue-Iris Error Setting Profile failed: {"result":"fail","session":"551d14591ec966eb5db53de556ff5 4b1 ","data":{"signal":"1","cxns":2,"cpu":12,"mem":"1.28G"," memf ree":"11.6G","memload":"26%","disks":[{"disk":"c:","allocated":40960,"used":3877,"free":166953, "to tal":244095}],"profile":1,"lock":"2","schedule":"Default","dio":[0,0,0,0,0,0,0,0], "uptime":"0:07:23:21", "clips":"Clips: 87 files, 3.78G/40.0G; C: +126.8G", "warnings":"0", "alerts":"30","tzone":"-480"}}
    Guessing I'm just not setting up the event correctly? Thanks for any help with this.
    Edit: Figured it out, the user that I had setup for Homeseer to access Blue Iris was not setup as an admin user. Once I changed that it works!
    Plugin's:
