Hi, BI v5 is about to be released. Any idea if this plug in will be OK with the changes ?
Blue Iris V5
Originally posted by S-F View PostDoesn't look like V5 offers much outside of a new UI.
This could also lead to having a video wall as well eventually.
Starting to use the new MS Video Api's for better CPU usage.
AI & Human recognition as well.
- 1 like
Been using BI4 (v. 4.8.4.6) for a long time and am very happy. I tend to find a version that runs well for me and then only update when either a fix becomes available for a problem I have experienced or a new interesting feature is added. As a result, my system is very stable.
Here is the doc that describes the major differences between BI4 and BI5.
https://blueirissoftware.com/BlueIris5.pdf
The enhancements would seem to be most attractive to installations with the following characteristics:- Lots of frequent interactions with the BI native UI. Apparently is will be more intuitive and modern.
- Installations with multiple instances of BI in production.
On #2, while I do have two unique BI4 installations at different locations, I manage them independently and haven't had a need to manage the two as one. However, my understanding is that BI is being used by independent security installers as their camera management software. I think some are even able to rebrand it. Potentially an installer might have many customers running BI and I can see that the installer might find it quite helpful to make a single change and have it affect all customer installations.
Unless new information becomes available, I won't be in any hurry to upgrade.
I see no reason to upgrade given my usage scenario at this point.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
I've put a call in to Ken to ask what changes in the v5 API to see if it will break the plugin or not. As soon as I have feedback I will post it here.
My gut feel is that it won't break but there will be an opportunity to add more functionality to the plugin. I'll know more when I hear back from the BI developer.Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
- 1 like
@berrygaz
Thanks for the plugin! It works great.
Maybe this is an opportunity to petition Ken to enhance the API with new functionality you might have wished for in the past. Since V5 will be marketed based on its new features and enhancements, having an improved API would be consistent with that marketing story.
For me, the one thing that would prompt me to upgrade would be better motion detection so that false positives are reduced/eliminated. I have two locations with HS3/BI4. One of them has lots of trees. When you combine trees, leaves, shade, and wind, you get lots of false motions that I have not been successful in tuning out. Add to that a pesky night time spider and the false positives negate the usefulness. Really I only care about motions of humans. Also, I'm not fond of motion detection as a function of the camera itself.
Originally posted by beerygaz View PostI've put a call in to Ken to ask what changes in the v5 API to see if it will break the plugin or not. As soon as I have feedback I will post it here.
Originally posted by Miamijerry View Post
OT, what works for me to prevent "False motion Alerts" is to use PIR and IR beam sensors which must trigger first, then these sensors change BI's profile to one that can send motion alerts, but only for 5 minutes if the are no more PIR or IR beam triggers.
Thanks for the idea!
Didn't think of that. I don't currently have any PIRs or IR beams outside but will try it. What is the range of your outdoor PIRs? I've never used beam IRs except on a garage door. I looked on amazon to see if there were any that were z-wave. Didn't find anything that was obvious it would work with HS3. Do you have a beam IR device you prefer? Do the ones you use run on batteries?
Thanks for the idea!-Wade
