Blue Iris love's NVR's
    Anyone have any success using an NVR as the primary device to capture your POE camera's and Blue Iris providing connection to Homeseer? I want to use the POE cameras on a vLAN to have both NVR and Blue Iris. I'm considering a Dahua NVR608 unit . Does Blue Iris need to look at the second stream for it's detection or motion to connect with Homeseer for actions?
    Dvoir
    I do exactly what your asking. I have a DVR running 24/7 recording, then BI for motion trggers and remote viewing. If I see anything of interest in the triggers I will go pull up the DVR for that time. Both running off primary stream. I dont use the HS addin as I dont see the value for my personal use, that said I am sure it would work.
      Out of curiosity, why do you use a separate DVR rather then use BI as the DVR?
        Maybe for action alerts, so it sends a http json post?
          milk3y
          I just finished installing all of my cameras today... terminated all of the cables and have all units online.....
          I was considering the Dahua NVR608-32-4k it only has two ethernet ports and requires a seperate POE switch.. I have installed Unifi 48 port POE for that task.
          Which NVR are you using? is your nvr a POE version or only have a single Ethernet which requires a separate switch .....Glad to hear you can have two devices reading the camera's main feed.
            Originally posted by devoir View Post
            milk3y
            There’s a couple Mikes on this thread.
            I use only Blue Iris. I have a duhua and axis cameras.
