Burrington I am using BI5 latest version and HS3..
I have added new action "Web request or MQTT" under camera settings > Alerts > Actions > On Alert
192.168.xx.xxx:80/JSON?request=pluginfunction&function=Alert&plugin=Blue-Iris&P1=&CAM&P2=&TYPE
I checked all motion zones. See attached picture..
Do you have it setup the same way? It looks like UI in BI5 is little bit different fro, BI4. Anything else that I should check? If it works for you, it should work for me too.. :-) Maybe I am just missing something simple.
Trigger not being sent from BI5
I've been getting motion triggers from BI5 and HS3 regularly including today. I'm using this and it seems to be working fine on latest versions of BI5, HS3, and BI Plugin:
IF Camera South has a motion alert in zone ABCDEFG
Not sure about the PI, but there was some change in HS4 that stopped JSON calls from BI to HS to not work without added username and password to the JSON call even though it worked in a browser.
Sent from my SM-G975U using Tapatalk
Originally posted by Charles_cz View Postmik3 Do you use camera itself sending motion alert over http to HS bypassing BI or just using alternative method to send alert from BI when camera is triggered in BI and sending it to BI plug-in over http?
Just trying to see if you are still getting benefits of BI motion detection.
Originally posted by Charles_cz View PostCan someone confirm that plug-in is not receiving trigger info from BI5 before I spend too much time on it? I really loved that feedback from BI. Now I get recording status with some delay but no more no status when camera is triggered.
Thanks, Charles
i send event updates over Json. Nothing is actually being sent. I can type the URL in a browser and Hs works.
as of now, I’m using the camera to send motion alerts over http.
Thanks, CharlesTags: None
