Hi Spud,
I just downloaded this plug-in, and I have not been able to connect to any cams.
I have 2 Wanscam and 2 ONVIF (USB cam connected to a QNAP NAS.
I have tried every possible URL, from LAN IP to WAN IP with port forward to the cams, with username and password, with &fmt=.jpg.
I am lost...
I guess trying to troubleshoot one of the wanscam would be the easiest.
I enable the plug in... all seem good, status says OK
Then add the network stream URL, obviously replacing the relevant info with actual values below, I have tried using:
http://[username]:[password]@[LANIP]:[port]/videostream.cgi (doesn't work on browser either)
http://[LANIP]:[port]/videostream.cgi?user=[username]&pwd=[password] this does work on browser)
http://[WANIP]:[port]/videostream.cgi?user=[username]&pwd=[password] this does work on browser locally and remotely)
I also tried adding &fmt=.jpg and ticking snapshot, and both above still work on browser.
No matter what I do, I get the following error in HS3 log:
FaceRecognition WARNING Recognition is not running, cannot stop it
FaceRecognition ERROR System.NullReferenceException: Unable to create capture from http://[IP]:[port]/videostream.cgi?user=[username]&pwd=[password]&fmt=.jpg at Emgu.CV.Capture..ctor(String fileName) at HSPI_FaceRecognition.FaceRecognitionApp.StartCapture()
I have also tried to set the log to debug... can't see anymore info... I tried to start and stop the FaceRecognition device manually, doesn't do anything.
I am running out of ideas here...
Thank you,
I am lost...
Thank you,
