This plugin is designed to detect and recognize people in videos feeds
This is an early Beta Version. From my limited tests the detection part works quite well, but the recognition part could (and will ) be more reliable. Please give me some feedback and report any bug.
Please read the User Guide before installing
FaceRecognition_3-0-1-0.zip
Installation:
Changes to v3.0.1.0
- update to Emgu 3.4.1
- update to lbpcascade_frontalface_improved.xml
Changes to v3.0.0.4
- Fixed bug when passing url containing "=" as a parameter of the Training Data manager
- Possibility to use different resolution for recognition
Changes to v3.0.0.3:
- Added "Faces Picture" device that dispay the detected faces even if none is recognized.
- Enhanced logs
Changes to v3.0.0.2:
- set default setting to process frame every 1s
- fixed minor bugs
Changes to v3.0.0.1:
- Added support for snapshot URL (Kinect now supported)
- Fixed memory leaks and a few minor bugs
Installation:
- download the above zip and save it in the HS3 application folder in /updates3/zips
- download the file named updater_override.txt and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Face Recognition Plugin" and check the Face Recognition line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
Changes to v3.0.1.0
Changes to v3.0.0.4
- Enhanced logs
- fixed minor bugs
