NetCam NameResolutionFailure accessing local network but works through external DDNS
    I've had NetCam working for a long time on this ZEE S2. About a month and a half ago it just stopped serving up video. Finally looking into this.
    All of the cameras are Foscam and installed around 2+ years ago. Most are FI9821P and a few newer R2 V4 models. Most of the cameras are current firmware.
    Observations on operability:
    - All cameras are accessible through the FOSCAM iPhone app
    - All cameras are accessible from a local PC on the LAN
    - All of the cameras are accessible via web browser remotely through the FIOS router via DDNS (and direct IP address)
    - All of the cameras are accessible when coded in NetCam Config as DDNS name. The Zee S2 can "reach out" and access the cameras
    - NONE of the cameras are accessible when the internal IP address is coded eg:
    http://192.168.1.238:10183/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=XXXX&pwd=YYYY
    I also tried the sledge hammer approach installingtUltraNetCam3 with the same NameResolutionFailure result.
    Has anyone experienced this and have a solution?
    Current version is: HS3 ZEE S2 Edition 3.0.0.500
    DHCP is enabled
    LAN IP Address: 192.168.1.8 (HomeTrollerZeeS2V2)
    Client IP Address:
    100.12.XXX.YYY
    (100.12.XXX.YYY)
    External IP Address:
    100.38.XXX.ZZZ
    (100.38.XXX.ZZZ)
    Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
    Web Server Port: 80
    Current Date/Time: 2/12/2019 12:09:54 PM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.500
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 49 Minutes 55 Seconds
    Number of Devices: 197
    Number of Events: 77
    Available Threads: 381
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    1.3.6.0: Device History
    3.0.0.14: NetCAM
    0.0.0.45: Pushover 3P
    3.0.1.252: Z-Wave
    Feb-12 11:48:47 CAM Error with request: Error: NameResolutionFailure
    Feb-12 11:48:46 CAM Error with request: Error: NameResolutionFailure
    Feb-12 11:48:45 CAM Error with request: Error: NameResolutionFailure
    Feb-12 11:48:44 CAM Error with request: Error: NameResolutionFailure
    I am having a similar problem but with Amcrest cameras. Auto discover does not work on Amcrest but still works on the Foscam cameras.
