Buy cameras for HS or Blue Iris and switch type?
    #16
    Originally posted by lj502 View Post
    I have been running Microsoft USB 720p lifecams (11) for over 3 years without one failure, all using USB extenders from monoprice (up to 100'). I had to add USB cards to my server to handle them all but they are inexpensive and simple. All the the cameras are powered off the USB port so as long as the server is on they are powered. Initially I started with them as a test and kept adding more, then I really liked the ease of setup add they just don't break. I recently lost most off my network to lightning even my blueiris server lost its HDMI output, the dust settled and the only thing left running (still on battery backup) was my server and all cameras filmed some awesome lightning.
    John
    instead of cards.. how about a usb powered hub?
    because now you got me looking at this...
      #17
      regular dome camera can experience reflections off the plastic dome and show up as artifacts in the recorded video.
      I have seen the same with all glass / plastic domes.
      These type do not have those reflections.
      - Pete
      Auto mator
      HS4 Pro - V4.1.10.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
      HS4 Lite -
        #18
        @Jeff
        pete.. got a model number on that? I would love one in white....
        For a while they had all kinds of colors. My exterior coach lights are all black. You could probably take the lamp apart and paint it white. This is the style of coach lights that I always see but they are either black or white.
        Here is the camera and link. I did the link pricing with a 4mm lense and POE. $281.00 USD with free shipping.
        They have another one for $171.99 USD here.
        I have purchased many cameras at this place and have not had an issue to date.
        Here is a black one but I do not know how much it is. Well too its a 2 MP camera so it much be cheaper.
        - Pete
        Auto mator
        HS4 Lite -
          #19
          How are you feeding to main server?
          Nothing fancy just an Asus I5 2.90 ghz with integrated graphics, win 7 64, and 3 USB cards. That machine runs 8 cameras and I have another smaller machine with 5 cams in the garage that feeds those cameras to the main server over my network. I ran 10 cameras for a while on the main server but I moved some cameras and decided to split the load, the main server rarely goes over 50% CPU load.
          John
          John
          Jay
            #20
            I setup cameras on the main server that pull the feeds from the garage server, like the garage sever is just another IP camera. I can pull up the setting later when I get back.
            John
              #21
              Garage Server
              John
              John
              That would great! To see the settings.
              Thanks Jay
                #22
                Have you had time
                John
                Just checking back on this.... How are you doing this?
                Thank you Jay
                Originally posted by Jayh391 View Post
                John
                Thanks Jay
