Foscam FI9831P Help with tilt/pan from app
  • Foscam FI9831P Help with tilt/pan from app
    Hi
    I bought a Foscam FI9831P and tried to integrate it with Hometroller zee S2 (2.00.206) on linux.
    There are two options from myhs.homeseer.com (Plugins --> HSTouchServer --> HSToush):
    1) Option 1: I checked "Auto Discover Foscam Cameras" but it did nothing. Did not pick up the camera.
    2) Option 2: Using "Manual Camera Setup", I added an entry with the following URL's snapshot: http://192.168.x.x:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=<username>&pwd=<password>
    with option 2, I can see the image from the android app. But, the controls are disabled (as in no tilt/pan).
    It seems like there is more configuration for the tilt/pan as shown on the menu:
    Pan Right Start:
    Pan Right Stop:
    Pan Left Start:
    Pan Left Stop:
    Pan Up Start:
    Pan Up Stop:
    Pan Down Start:
    Pan Down Stop:
    Can anyone please share what would these values be? Thanks
    a.
    Was hoping. Someone was going to provide some direction
      Hope this helps...
      Edit the xxx for user,password and address
      PHP Code:
      http://192.168.0.xxx/decoder_control.cgi?command=5&user=xxx&pwd=xxx      <---- Stop Patrol
      http://192.168.0.xxx/decoder_control.cgi?command=31&user=xxx&pwd=xxx    <---- Go to preset 1
      http://192.168.0.xxx/decoder_control.cgi?command=33&user=xxx&pwd=xxx    <---- Go to preset 2
      http://192.168.0.xxx/decoder_control.cgi?command=4&onestep=5&user=xxx&pwd=xxxx   <--one step to left and stop
      http://192.168.0.xxx/decoder_control.cgi?command=6&onestep=7&user=xxx&pwd=xxx    <-- one step to right and stop
      http://192.168.0.xxx/decoder_control.cgi?command=0&onestep=1&user=xxxi&pwd=xxx    <-- one step up and stop
      http://192.168.0.xxx/decoder_control.cgi?command=2&onestep=3&user=xxx&pwd=xxx    <-- one step down and stop
      Don
        See this post:
        http://board.homeseer.com/showthread...49#post1209749
        - Robert
          Hi Don,
          You posted seven lines while the screenshot i attached has eight. Can you please match the entries as per the screenshot if possible. Thanks
          Pan Right Start:
          Pan Right Stop:
          Pan Left Start:
          Pan Left Stop:
          Pan Up Start:
          Pan Up Stop:
          Pan Down Start:
          Pan Down Stop:
            These are the only ones I use, up,down,left,right,preset 1, preset 2. I don't use the stock hstouch camera page. Sorry.
            Did you look at Robert's link?
            Don
