How to setup if cameras are connected to NVR?
    I have Hikvision cameras and their POE NVR.
    The cameras are connected directly to POE ports on the Hikvision NVR, they have different IP subnet assigned by the NVR - 192.168.254.x , which are not accessible since my home subnet is 192.168.1.x
    I can only access the cameras directly by going through the NVR's IP
    Camera 1 - 192.168.1.10:65001
    Camera 2 - 192.168.1.10:65002
    ... 65003
    ... 65004
    In this case, is it possible to setup the cameras in HS3 ?
    the URl calls for rstp://x.x.x.x:554/ch1/...... but how do i define port 554 ?
    I have asked the same question. Short answer is hstouch does not natively do RTSP. I am still looking for ways to transcode it.
      If you use the Sighthound plugin you can see your cameras with HSTouch as a device. I'm not sure about streaming but snapshots for sure. The only short coming to this is the need for a Sighthound Server which costs. Another option is Blueiris plugin
      Sent from my A0001 using Tapatalk
        ... 65003
        ... 65004
        Has anyone found a solution to this yet?
          HSTouch at the current revision level is streaming RTSP.
          What HSTouch client are you using?
          Using Firefox do the following stuff....bring up a stream and right click the properties, copy the properties to another tab to watch the stream. Then paste the copy and paste here for the stream.
          - Pete
          Auto mator
          HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
          6.10.0.104
          HS4 Lite -
            RTSP is there in the later versions, but still far from usable. You have to restart the HSTouch server plugin nightly to maintain. Otherwise the picture just freezes.
            Really really hope that HSTouch gets some focus again soon.
              I am trying to integrate an rtsp feed from the Dahau NVR to Imperihome (directly, not through Spud's plugin). Do you know the exact format of the rtsp url that I should enter? For Imperihome it states that user authentication is not supported so I presume I just don't enter it in the string.
              From the NVR settings, it states the rtps URL should be
              rtsp://<user><pass>@<IP Address>:<Port>/cam/realmonitor?channel=1&subtype=0
              with
              channel:Channel 1-8
              subtype: Code-Stream Type, Mainstream 0, substream 1
              What exactly should I enter?
                That is what I have. You have to authenticate though otherwise you won't get a feed.
                  What was the rtsp string you used to get it working in HStouch?
                    Can you do an mjpeg or jpeg capture of the stream?
                    Start by testing inside of your network with HSTouch.
                    As Wayne has mentioned there are problems with the RTSP streaming stuff in HSTouch.
                    What HS touch client are you using? Windows, iOS or Android?
                    I personally have downgraded my HSTouch windows clients to V.32 and V.36 and just using jpg snapshots or VLC in a window streaming.
                    You can test RTSP streaming on your client by running VLC and command line you mentioned above. It should work this way.
                    To configure RTSP streaming with HSTouch do the following:
                    1 - Test the RTSP command line in VLC. See picture #0. If this doesn't work you cannot proceed to step #2.
                    VLC is available for Windows, Linux and Android. Not sure on iOS. Test the command line RTSP stuff on your Homeseer server and the client running VLC.
                    2 - Go to your HSTouch server configuration and manually add an RTSP stream as you see in the attached picture #1
                    3 - Create a new design in HSDesigner. Put the proxy hxxp as seen in the picture below as you RTSP camera. Upload the new design to your client.
                    You should see the RTSP stream as you do in step #1. Also test the client running on your HS server.
                    Readers - if I have skipped a step here please let me know and I will edit the above. The test below is a direct RTSP connection to one IP HD camera.
                    For the above mentioned RTSP NVR connection you would test VLC with:
                    in the network URL:
                    For my Zoneminder box I capture using RTSP and stream using MJPG. IE: such that my stream is this:
                    1 - In Zoneminder the source path is configured as: rtsp://<IP Address>/4?tcp
                    2 - In Homeseer touch client the video is configured as: hxxp://<IP Address>/zm/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=5&buffer=1000&monitor=9 (I just drop the html in the video box and do not need to use the HS touch configuration).
                    - Pete
                    Auto mator
                    6.10.0.104
                    HS4 Lite -
                      I was hoping to get it working in Imperihome. The RTSP streams work fine in other android programs (The one supplied by Dahua ie gdmss and a third party one: RTSP Player which supports authentication).
                      The RTSP url that works for me is
                      rtsp://<user>:<password>/192.168.x.xxx:554/cam/realmonitor?channel=4&subtype=1
                      where channel is from 1-8 and subtype 1 is the substream (lower bandwidth) and 0 is the main
                      It would be nice to integrate IP cam viewing into the one app but I can wait until Imperihome supports it. I have tried HSTouch but I just don't have the time to mess with it.
                        Just use the above RTSP link for your Homeseer touch server configuration and insert the proxy IP in HSDesigner. It should work fine.
                        Homeseer allows for the most flexibility relating to touch design. Personally here run IPSec VPN on the HSTouch tabletop to connect from outside of the home.
                        Here do not utilize Imperihome.
                        Note for streaming HD on the internet you do need a big uploading pipe. Test it. Open up the RTSP stream on your firewall. Tether your phone to a laptop or android tablet and using VLC to stream your IP camera.
                        It might be easier if you can do mjpg or jpg from the NVR streams. Can you do a single jpg capture from the NVR or an mjpg streaming capture from the NVR?
                        - Pete
                        Auto mator
                        6.10.0.104
                        HS4 Lite -
                          Mike
                          For my Hikvision NVR I use.
                          http://user: password@xxx/ISAPI/Streaming/channels/101/picture
                          101 = Camera one, stream 1.
                          201 = Camera two etc.
                          xxx IP is the NVR IP.
