Wanted to integrate some Raspberry Pi camera's into HS3 using MotionPie. Is there a suitable plugin for HS3 that will work with a MJPEG stream?
HS3 Plugin for MJPEG stream
Hi Al,
Just tried it with the following settings:
- Camera Type with default paths (for some reason I cannot edit Video Stream Path).
- No Controls
- DEVICES address: http://192.168.1.30
TCP Port: 8081
Model: Pi (as above)
Username & Password
Created Event to take snapshot but got "The Snapshot request sent to NetCam001 [Porch] failed: The remote name could not be resolved: 'http'"
I can view the camera in explorer okay.
I am using the MotionPie software in simple MJPEG mode.
The http part should not be entered with the ip address. What is the video stream path for the device? Does it have a snapshot path as well? I tried editing those for my camera types and I can easily edit them.
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
My mistake, i dont have http:// entered in ip address.
under 'Edit Network Camera Type', I cannot change the contents of 'NetCam Videostream Path' . Currently it has '/videostream.cgi'
i've nowgot one day left on trial so looks i'm buggered anyway.
BTW, Im using a Motioneye by Calin Crisan. And using it in 'Fast Network Camera' mode. In this mode it only support MJPEG streaming which is ideal fast frame rate when viewing.
If anyone is successful with this, i would appreciate some feedback
John.
