HS3 Plugin for MJPEG stream
  • HS3 Plugin for MJPEG stream
    Wanted to integrate some Raspberry Pi camera's into HS3 using MotionPie. Is there a suitable plugin for HS3 that will work with a MJPEG stream?
  • #2
    Have you tried UltraNetCam?
    Cheers
    Al
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
    • #3
      Hi Al,
      Just tried it with the following settings:
      - Camera Type with default paths (for some reason I cannot edit Video Stream Path).
      - No Controls
      - DEVICES address: http://192.168.1.30
      TCP Port: 8081
      Model: Pi (as above)
      Username & Password
      Created Event to take snapshot but got "The Snapshot request sent to NetCam001 [Porch] failed: The remote name could not be resolved: 'http'"
      I can view the camera in explorer okay.
      I am using the MotionPie software in simple MJPEG mode.
      • #4
        The http part should not be entered with the ip address. What is the video stream path for the device? Does it have a snapshot path as well? I tried editing those for my camera types and I can easily edit them.
        Cheers
        Al
        • #5
          My mistake, i dont have http:// entered in ip address.
          under 'Edit Network Camera Type', I cannot change the contents of 'NetCam Videostream Path' . Currently it has '/videostream.cgi'
          i've nowgot one day left on trial so looks i'm buggered anyway.
          BTW, Im using a Motioneye by Calin Crisan. And using it in 'Fast Network Camera' mode. In this mode it only support MJPEG streaming which is ideal fast frame rate when viewing.
          If anyone is successful with this, i would appreciate some feedback
          John.
          • #6
            Hi John,
            There should be an edit link. If you don't see it, which browser are you using? Can you post a screen shot? If you contact HS, they will typically extend the trial licenses.
            Cheers
            Al
            • #7
              Motioneye stream on netcam
              John,
              Did you ever find a solution to this?
              • #8
                What do you need to do with the MJPEG stream? You can just grap a static image from it with a quick script if you wanted to send the image somewhere. Or are you after complex motion detection and the like?
                My Plugins:
                Pushover 3P | DoorBird 3P | Current Cost 3P | Velleman K8055 3P | LAMetric 3P | Garadget 3P | Hive 3P |
                Yeelight 3P | Nanoleaf 3P
                • #9
