How do I take 5 pictures 1 second apart and email each one
  • How do I take 5 pictures 1 second apart and email each one
    I am trying to have netcam take 5 pictures, 1 second apart, and send each one by email. When I try to do this with an event, it doesn't work properly.
    I have the event like this:
    netcam take picture
    send an email with attachment current picture
    netcam take picture
    I have tried adding a wait 1 second between netcam take picture and send email. Result I only get 1 picture. No idea why. Weird.
    You can do this with a script but I am not sure that you can do this with Netcam.
    Thinking I did try many years ago.
    With an NVR capturing an event you can capture say minutes of an event frame by frame and just send a compressed video / twenty frames in one picture email out if you wanted to.
    More cams more pictures. IE: the two below are one camera out of three (there are three videos of each event below from different views).
    - Pete
    Auto mator
    HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      I wasn't sure if I can do this properly with events, so after I posted this here I posted this in the script section too.
        Greg Miner wrote a capture script around 2012 that worked well in this fashion for Homeseer 2.
        Thinking many other users went to manual events / script captures back then.
        I use to use it all of the time back then.
        Here is one described from 2011 for Homeseer 2.
        This script allows you to capture Webcam images.
        - Pete
        Auto mator
        HS4 Lite -
