Plugin stops working
  • Plugin stops working
    Hello!
    The Plugin Surveillance Station quits very often (See Screenshot)
    I have 3 Cameras in my Surveillance Station, but only 1 is active / connected because we are relocating.
    So i get errors like this: The Snapshot request sent to NetCam002 [FI9828P] failed: The operation has timed out
    But this should not lead to unexpected outages of the plugin.
    Has anyone the same problem?
    Thank you in advance!
    Kind regards
    Chris
    Here is the System Profile:
    Current Date/Time: 09.03.2017 10:34:24
    HomeSeer Version: HS3 Pro Edition 3.0.0.312
    Operating System: Microsoft Windows Embedded Standard - Work Station
    System Uptime: 1 Day 9 Hours 22 Minutes 14 Seconds
    IP Address: 192.168.25.21
    Number of Devices: 386
    Number of Events: 100
    Available Threads: 200
    Enabled Plug-Ins
    3.2.0.5: APCUPSD
    2.0.1.0: BLFloorplan
    2.0.4.0: BLInterface
    2.0.10.0: BLRfid
    2.0.34.0: BLSecurity
    2.0.69.0: BLStat
    1.1.2.0: Device History
    3.0.0.30: EasyTrigger
    3.6.5.0: Harmony Hub
    3.0.0.75: HSTouch Server
    3.0.0.13: ImperiHome
    3.0.0.27: MediaController
    3.0.0.11: NetCAM
    0.0.0.30: Pushover 3P
    1.0.0.4: Restart
    30.0.0.33: RFXCOM
    3.0.0.21: Sonos
    1.0.1.0: SurveillanceStation
    3.0.6260.19461: UltraMon3
    3.0.6119.21453: UltraNetCam3
    3.0.5902.19061: UltraSMTP3
    3.0.1.102: Z-Wave
    Mmmm ... it shouldn't crash :-).
    Let me have a look at it (probably somewhere this weekend).
    Does it always crash when trying to create a snapshot on a cam that is not connected ?
    Can you maybe enable debug tracing and send me the log ?
      I am not able to reproduce the problem.
      Can you send the debug log ?
      Is the cam disconnected or the entire synology ?
      Is the status of the cameras/synology in HS up-to-date ?
      Are you using the latest plugin version from the HS store ?
