Contacting HomeSeer This Week
See more
See less
ModBUS interface ?
  • ModBUS interface ?
    Hi
    I've got the synology surveillance station setup and I'm looking at generating events from I/O devices. Can your plugin interface as an I/O module in Surveillance station ?
    Thankyou..Peter
    HS 2.2.0.11
    Hi,
    The plugin can't work as an IO module.
    Is there an API available for IO modules ?
      HI There...
      Under surveillance station you can connect an I/O device to Synology to control outputs etc.
      It appears its rudimentary ModBUS in Ascii mode. You create an event in Surveillance station to toggle an I/O pin for alarm notification etc.
      Here is some python code I found that works....I had this running on a raspberry PI and had the synology connect to it. (test connection). I'm waiting for my additional licence so I can do more testing and create events
      https://gist.github.com/hdo/792eebcb...5069e325a0e520
      Cheers..Pete
      HS 2.2.0.11
        Thanks, look interesting !
        But, what can you do with it that you can't do currently with the plugin ?
          Talk to an external I/O device ?
          Sent from my SM-N910G using Tapatalk
          HS 2.2.0.11
            Maybe I've understood you wrong, but I thought that you had a virtual IO device (the python script) which SurvStation controlled when events occurred. I think the plugin can handle all the events that you used previously with the virtual device, or not ?
            Or ... do you want to control a real IO device from HomeSeer ?
              Hi Kriz
              OK clearly I dont know enough about your plugin. I'll be home later today and will install it...
              What I was looking to do was for Surveilance Station to trigger a motion event (it currently sends me an e-mail), I want it as an input to trigger a HS event. If your plugin does this then fantastic :-)
              Equally I'm going to read up some more on ModBUS and python, it looks very interesting :-)
              Cheers..Peter
              HS 2.2.0.11
                That's exactly what the purpose of this plugin is :-)
                Check the attached help for setting it up.
                  OK, now I see. You do it a different way via the "SMS" interface.....
                  I'll have a look, thanks for taking the time to get the message across :-)
                  I'm almost home from an international work trip, the synology did an update and didnt come back so I've got to wait till I get home to reboot it...
                  Thankyou..Peter
                  HS 2.2.0.11
                    Kriz
                    I'm probably going to use the ModBUS protocol to talk to a raspberrypi to manage I/O events and tie them into the I/O on the arduino.
                    I've got the python code working, I'm able to flip GPIO bits on the raspberry when getting motion events from the Synology.
                    I've only got 2 cameras I need events from so this will do...
                    Thanks for your help, its all been an interesting learning exercise.
                    Pete
                    HS 2.2.0.11
                      Ok. Out of curiosity...what is wrong with using sms events? Think is is less work
                        Kriz
                        Seriously nothing wrong at all..I just started down this path and wanted to get my head around python and make it myself :-) I'm going to have a closer look at your implementation, its a clever way to do it too :-)
                        I have so many raspberrypis sitting here, I had to do something with it :-)
                        Again, no issues at all with your implementation, I was just interested in understanding python and UDP
                        Cheers..Pete..
                        p.s I had to buy the extra licence to use the 3rd device, I cant believe they physically mail you something, why dont they E-mail it to you instead :-) I think I might buy another licence to put a 3rd camera on. I do like my DS916+...
                        HS 2.2.0.11
                          Kriz
                          So after a while i found that the internal Hikvision's line crossing detection was what i needed. I ended up creating a postfix/procmail setup on my beaglebone to trap alarm emails and toggle a gpio pin to toggle an arduino input....
                          Good fun experimenting
                          Sent from my SM-T550 using Tapatalk
                          HS 2.2.0.11
