ModBUS interface ?
  • ModBUS interface ?
    Hi
    I've got the synology surveillance station setup and I'm looking at generating events from I/O devices. Can your plugin interface as an I/O module in Surveillance station ?
    Thankyou..Peter
    HS 2.2.0.11
  • #2
    The plugin can't work as an IO module.
    Is there an API available for IO modules ?
    • #3
      HI There...
      Under surveillance station you can connect an I/O device to Synology to control outputs etc.
      It appears its rudimentary ModBUS in Ascii mode. You create an event in Surveillance station to toggle an I/O pin for alarm notification etc.
      Here is some python code I found that works....I had this running on a raspberry PI and had the synology connect to it. (test connection). I'm waiting for my additional licence so I can do more testing and create events
      https://gist.github.com/hdo/792eebcb...5069e325a0e520
      Cheers..Pete
      HS 2.2.0.11
      • #4
        Thanks, look interesting !
        But, what can you do with it that you can't do currently with the plugin ?
        • #5
          Talk to an external I/O device ?
          Sent from my SM-N910G using Tapatalk
          HS 2.2.0.11
          • #6
            Maybe I've understood you wrong, but I thought that you had a virtual IO device (the python script) which SurvStation controlled when events occurred. I think the plugin can handle all the events that you used previously with the virtual device, or not ?
            Or ... do you want to control a real IO device from HomeSeer ?
            • #7
              Hi Kriz
              OK clearly I dont know enough about your plugin. I'll be home later today and will install it...
              What I was looking to do was for Surveilance Station to trigger a motion event (it currently sends me an e-mail), I want it as an input to trigger a HS event. If your plugin does this then fantastic :-)
              Equally I'm going to read up some more on ModBUS and python, it looks very interesting :-)
              Cheers..Peter
              HS 2.2.0.11
              • #8
                That's exactly what the purpose of this plugin is :-)
                Check the attached help for setting it up.
                • #9
                  OK, now I see. You do it a different way via the "SMS" interface.....
                  I'll have a look, thanks for taking the time to get the message across :-)
                  I'm almost home from an international work trip, the synology did an update and didnt come back so I've got to wait till I get home to reboot it...
                  Thankyou..Peter
                  HS 2.2.0.11
                  • #10
                    Kriz
                    I'm probably going to use the ModBUS protocol to talk to a raspberrypi to manage I/O events and tie them into the I/O on the arduino.
                    I've got the python code working, I'm able to flip GPIO bits on the raspberry when getting motion events from the Synology.
                    I've only got 2 cameras I need events from so this will do...
                    Thanks for your help, its all been an interesting learning exercise.
                    Pete
                    HS 2.2.0.11
                    • #11
                      Ok. Out of curiosity...what is wrong with using sms events? Think is is less work
                      • #12
                        Kriz
                        Seriously nothing wrong at all..I just started down this path and wanted to get my head around python and make it myself :-) I'm going to have a closer look at your implementation, its a clever way to do it too :-)
                        I have so many raspberrypis sitting here, I had to do something with it :-)
                        Again, no issues at all with your implementation, I was just interested in understanding python and UDP
                        Cheers..Pete..
                        p.s I had to buy the extra licence to use the 3rd device, I cant believe they physically mail you something, why dont they E-mail it to you instead :-) I think I might buy another licence to put a 3rd camera on. I do like my DS916+...
                        HS 2.2.0.11
                        • #13
                          Kriz
                          So after a while i found that the internal Hikvision's line crossing detection was what i needed. I ended up creating a postfix/procmail setup on my beaglebone to trap alarm emails and toggle a gpio pin to toggle an arduino input....
                          Good fun experimenting
                          Sent from my SM-T550 using Tapatalk
                          HS 2.2.0.11
