Contacting HomeSeer This Week
See more
See less
.NET Errors
  • .NET Errors
    Hi
    I am still seeing errors from time to time, where the plugin stops and gives this error.
    Log Name:      Application
    Source:        .NET Runtime
    Date:          25-05-2017 03:23:13
    Event ID:      1026
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      macbookair11
    Description:
    Application: HSPI_SurveillanceStation.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.NullReferenceException
       at Synology.SurveillanceStation.ApiCameraListCommand.setFailedResult()
       at Synology.SynologyBase.Execute(Synology.IApiCommand)
       at Synology.SurveillanceStation.SurveillanceStation.getCameraList()
       at Synology.SurveillanceStation.Facade.SurveillanceStationFacade.<RequestCameraList>b__30_0()
       at Synology.SurveillanceStation.Facade.SurveillanceStationFacade.Run()
       at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
       at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
       at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
       at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
       at System.Threading.ThreadHelper.ThreadStart()
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name=".NET Runtime" />
        <EventID Qualifiers="0">1026</EventID>
        <Level>2</Level>
        <Task>0</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2017-05-25T01:23:13.000000000Z" />
        <EventRecordID>2277</EventRecordID>
        <Channel>Application</Channel>
        <Computer>macbookair11</Computer>
        <Security />
      </System>
      <EventData>
        <Data>Application: HSPI_SurveillanceStation.exe
       at Synology.SurveillanceStation.Facade.SurveillanceStationFacade.&lt;RequestCameraList&gt;b__30_0()
    </Data>
      </EventData>
    </Event>
    Hi,
    So switching .NET versions fixed the crash.
    Can you enable debug logging and send it to me ?
    / Kriz
      I assume you mean after the next .NET error?
        Yes
          Hi,
          According to our PM conversation, you are using SS 8.
          Can you check:
          - if updating to the newest version of the plugin fixes the issue (new version 1.0.1.1 is pushed now)
          - Do you have sufficient priviliges ? Try with the admin account.
            Hi
            I have not seen the issue since updating to the newest version. Thanks!
