Update to 1.0.1.1 failure
  • Update to 1.0.1.1 failure
    I'm having issues getting the plugin to update from 1.0.1.0 to 1.0.1.1
    I disable the plugin, I verify that the exe was shutdown on the system that runs HS3, I click the update and start the install, during the install the hspi_surveillancestation.exe starts up without me enabling the plugin, and then the install fails. The logs indicate that the exe couldn't be overwritten, obviously since it is running.
    I have manually killed the process many times to no avail.
    what now?
    Mmmm ... this is new to me.
    I'll try to do some invest tonight.
    I guess it'll work if you manually overwrite the file ...
    link
      I've changed something in the install script.
      Can you check if it is OK now ?
        It's working now.
        Thank you.
          Thanks for letting me know !
