SurveillanceStation Plug-in breaks restart system option
  • SurveillanceStation Plug-in breaks restart system option
    I have a "problem" when the SurveillanceStation plug-in is enabled the system shutdown or restart doesn't work wel.
    Homeseer does shutdown but the Raspberry PI 3 doesn't stop / restart.
    When I disable the plug-in restart/shutdown system works fine
    Who nows a solution?
    I'm running HS3 version 3.0.0.357 on a raspberry PI3 SurveillanceStation Plug-in version 1.0.1.1
    Hi,
    Could you enable debug logging and send it to me ?
      Originally posted by kriz83 View Post
      Hi,
      Thanks for the fast repley, I wil do that.
      Enable debug logging, and then try a restart? Is it the normal log file or a seperated ServeillanceStation log file, that you need?
      Regards Paul.
        Regards Paul.
        Hi, See attachement.
        The log file is ziped 3,8 MB, I can't upload it, where can I email it to?
        Current Date/Time: 10/7/2017 8:52:12 AM
        HomeSeer Version: HS3 Standard Edition 3.0.0.357
        Linux version: Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux System Uptime: 0 Days 19 Hours 13 Minutes 1 Second
        IP Address: 192.168.178.74
        Number of Devices: 598
        Number of Events: 185
        Available Threads: 399
        Enabled Plug-Ins
        3.0.0.20: A10
        3.6.5.0: Harmony Hub
        3.0.0.28: Nest
        3.0.0.14: NetCAM
        3.0.0.10: P1
        0.0.0.34: Pushover 3P
        3.1.0.20: Sonos
        1.0.1.1: SurveillanceStation
        3.0.1.130: Z-Wave
