Log Errors - Devices show Disconnected.
  • Log Errors - Devices show Disconnected.
    Enabled the plugin
    Configured it to use https and port 5000
    Devices show up but get errors in the log and when the plugin starts
    This is on windows 10. .NET 4.5 is installed by default.
    Dec-16 6:04:29 PM SurveillanceStation Error System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: The handshake failed due to an unexpected packet format. at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceiv e(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsync Result lazyResult) at System.Net.TlsStream.CallProcessAuthentication(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionConte xt executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result) at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.ConnectStream.WriteHeaders(Boolean async) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at Synology.WebRequest.GetUrl(String url, UInt32 timeout) at Synology.SynologyBase.Execute(IApiCommand cmd)
    Dec-16 6:04:27 PM SurveillanceStation Warning Retry #2 URL: https://192.168.1.252:5000/webapi/qu...on=1&query=ALL
