Need some help if possible
  • #31
    Can you check that motion detected message in Synology is the same as in your plugin ?" The subjects need to align.
    • #32
      OK this is my set up.
      The messages align see belowClick image for larger version
      the rest of my set up is as follows. Can you spot anything?
      I can't seem to figure out why the motion is not working. Comms are working, as when I change the home mode on my server it changes in HS. So that good. The messages are aligned but when I try to send a test SMS from the server to HS it just seems like nothing is received or sent.
      It is so annoying as I have had the test SMS messages appear before, see previous posts in this thread, it just I did not have text aligned. Now i know that, i have something wrong somewhere else.
      ArGHHHHHHH
      • #33
        Right, I have been playing all morning with the plugin and the only way I can get it to work for motion events is by using webhooks and running an event that changes the state of a cam if motion is detected and then setting to connected after a minute.No matter what I do I just can't seem to get the motion detected working via SMS notification.
        The home status works well and so does the connected/not connected status. The auto population of cams also working well.
        Comms is working well between HS and Sstation.
        the only thing I can put it down to is the following. Ie the URL used in Sstation when sending the sms to HS. I guess I must have extra spaces or the format is wrong. Have checked.
        The current format is this.
        "http://ben:ben@192.168.1.115:80/JSON?request=pluginfunction&function=smsnotification&plugin= SurveillanceStation&P1=Hello+World&user=unused&password=unus ed&to=bla"
        Thanks for all your help and patience.
        • #34
          Can you turn on debug logging?
          Try to disconnect and reconnect a camera, then try to activate motion on it. You are sure your cam is configured for motion alerts ?
          Send me the output via PM
          • #35
            Hi, i am deff getting motion from SStation. See enclosed. This is an Sstation event running when my cams detect motion and then running webhooks to turn on a HS event.
            As you can see. Sstaion is firing off events but nothing happens with SMs notifications as per your set up. I will send you my log file via pm.
            • #36
              I have not received any log files. Can you post one of your events that should have triggered ?
              • #37
                HI kriz. I tried Pm you the HSsurveilance station log file but it was too large. Not sure what exactly you want me to send. sorry. I am a total pain in the arse i know.
                • #38
                  Can you put it on pastebin and send me a link ?
                  Search for your password in the text file and do a replace, if necessary.
