Updated to 1.1.0.0 - not connecting to SS any more
  • Updated to 1.1.0.0 - not connecting to SS any more
    Hi,
    I just updated the plugin to 1.1.0.0 and now I get "Failed to login (errorcode: Synology.SurveillanceStation.API.ErrorCode" in the log. Everything worked before the update.
    Hope you can help.
    Michael
    Can you turn on debug logging and send it to me?
    Verstuurd vanaf mijn SM-G965F met Tapatalk
      I think the problem is the parsing of my password to log into SS. My password ends with "?". When the plugin sends the credentials
      [5:30:27 PM] [DEBUG] url=http://xxx.xxx.xxx.xxx:5000/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=2&account=XX XX&passwd=XXXXX&session=HSPI_SurveillanceStation&format=sid
      the "?" at the end of the password is turned into "%3f".
      Best,
      Michael
        What happens if you paste the url in your browser? What if you change your manually replace your password in the URL with the 'correct' one ?
          I get
          {"error":{"code":400},"success":false}
          However, if I replace session=HSPI_SurveillanceStation with session=SurveillanceStation I get the session ID token
          {"data":{"sid":"Lwd6rTH3oK0yk14B0MPN671251"},"success":tr ue}
            Mmm, that is strange. It works over here :-)
            I'll update the plugin ASAP
              Can you try attached version ?
                Still can't connect to SS. The "?" in the password still parses wrong. I sent you my log file.
                I'm running a Homeseer Zee S2, not sure if that is relevant.
                Michael
                  Latest version of plugin (1.1.3.0) solves the problem. Thanks!
                    Mine is also not working but I cant seem to update to 1.1.3.0. Everytime I do it says it was successful but it still shows the new version in the updater.
                      Mmm, that is strange. Anything particular in the logs? Seems like something for HST to invest. Do you have a password containing strange characters ?
