HS4
    HS4
    Will you be updating this software Plug-in to work with HS4?
    Thanks in advance,
    Grant
    Unfortunately It is too much effort for me to update the plugin for HS4. I currently don't have the time for it, and the effort vs revenue ratio is too low (at the moment). Also, HS3 plugins work fine in HS4. This makes me wonder how many people will be willing to pay the upgrade fee for some graphical tweaks.
    Maybe in a year when HS4 has gained popularity (and maturity), i might create an upgrade. Probably not the answer you were looking for, sorry :-(
    I will continue to support this plugin and it should work fine in HS4 ( i recently added the home/away feature for example)
      I've upgraded to HS4, since than the sms push feature from surveillance camera plugin is not working anymore. Any ideas?
      regards,
      Maurice
        Apparently the web/json api changed a bit in HS4, something with credentials. There's a thread about it somewhere on the forum.
          Is there already a fix for the credentials isue?
            What issue are you talking about? For triggering the motion? That is something to do with HS4 ...
              I have a login error, see screenshot, the cridentials are ok.
                Got any special characters in your PW? <space> ? ! @
                  No password is generated by Synology, and in HS3 it worked.
                    I see that my synology blokked the IP from my HS4 systeem I'm try to release it
                      Login works now
                      New error: Failed to retrieve cameralist
                        Does your user have admin rights ?
                          I made a new user, with only read rights
                          Now its ok, the cameras are in the device list.
                          Thanks for the fast responses
                            The motion works for me.
                            Synology cam detects motion -> HS4 device change status -> event trigers -> action
