Synology Surveillance Station plugin
  • Synology Surveillance Station plugin
    Hi,
    A first version of the plugin is available (link)!
    I look forward to hearing your comments and suggestions !
    Excellent work!
      zip needs repackaged
      I just installed your plugin successfully; but only after renaming the zip.
      Your override is looking for Surveillance-1.0.0.0.zip but you have it named Surveillance.zip instead.
      Thank you once again.
      I will let you know how the plugin works.
        I have many Synology devices, and the one I'm testing with your plugin does not currently have any devices in SS. I have setup the .ini and initialized the plugin.
        It created the root device but shows disconnected. The logs are not telling me anything useful for troubleshooting. I have 2 factor authentication enabled on the DS713, is that causing an issue?
        Here is the error in the logs when I start the plugin:
        SurveillanceStation Error System.Net.WebException: The remote server returned an error: (400) Bad Request. at System.Net.HttpWebRequest.GetResponse() at Synology.WebRequest.GetUrl(String url, Int32 timeout) at Synology.SynologyBase.Execute(IApiCommand cmd)
          I will fix the zip file tomorrow. I did a last minute fix and forgot to rename the file. No idea if 2FA has any influence, will try it soon. Is there any logging?
          Verstuurd vanaf mijn Nexus 7 met Tapatalk
            renanamed the zip to the one in the .config file.
            Awesome plugin! My cameras lock up occasionally, so this is great new monitoring ability I can use telnet to my POE switch to reset the power for that port for 5 seconds.
            I have 24x7 recording and external DSC IR/Microwave Exterior Motion sensors, so don't need the snapshot or motion control.
            One question, I use Imperihome which has cameras configured via URL for MJPEG or JPEG.
            Do you know if there is any way I can configure the Imperihome to hit the Synology server for JPEG images or MJPEG feed. That the cameras only have one client (synology), otherwise I have 3 camera clients (synology + 2 imperihome clients) and it causes lock up randomly on one camera.
              AgileHumor do you have 2 factor auth setup on your Synology?
              The one I have the plugin pointed at has it authenticated and shows disconnected, even though the URL, port, username, and password are correct.
              Any thoughts?
                Yep, 2FA breaks it :-/
                https://forum.synology.com/enu/viewtopic.php?t=117664
                There is an otp_code param in other api docs, which is used for 2FA. But how would u enter it ?
                  Just installed the beta manually...so far so good.
                  feedback/questions/suggestions:
                  i would suggest reaching out to rich at homeseer and see if he will set you up to post your own betas in the Beta section of the Updater. Since you have your own server, you can post updates on your own.
                  the motion trigger seems to be working; any chance you can have the plugin make these configurations?
                  do you plan to give homeseer the ability to view the snapshots? or how can we do this? Ultimately i would like to replace the NetCAM plugin with this one.
                  Mark
                  HS3 Pro 3.0.0.534
                    HTTPS
                    I use HTTPS on port 5001. Is there a way to configure for that? The debug string says it's using http.
                    Looking forward to getting this to work, it's a great idea
                      I'm using hs3 3.0.0.152 and it getting a broken image on the Connected status
                      the following doesn't exist
                      http://homeseer:82/images/HomeSeer/status/green.png
                      i would suggest putting/copying any image you want to use into your images/surveillancestation folder and don't rely on the images in the homeseer folder.
                      to make your plugin linux compatible you may need to use all lower can paths as well
                      Last edited by mnsandler; May 7th, 2016, 04:17 PM. Reason: to make your plugin linux compatible you may need to use all lower can paths as well
                      Mark
                      HS3 Pro 3.0.0.534
                        so there must be a minimum version of HS3 required to use the JSON triggers. I upgraded from .152 to .187 and it still didn't work. So I upgraded to the latest release .280 and everything worked as expected.
                        You can put a minimum version required in your install.txt or maybe just add it to your requirements.
                        Thank you very much for taking on this plugin. Its going to be extremely helpful.
                        Mark
                        HS3 Pro 3.0.0.534
                          According to the API, it is possible to retrieve the URL of the 'live snapshot', but how would you use this ?
                          I will after the plugin is a bit more matured. Thanks for the tip !
                          That is hard, because then I would need to know username, password, port number etc. However, in a near future release I will use the SMS service provider interface, and then you only need to do it once (and not for every cam)
                          Low prio at the moment because you can see it in Surveillance Station. Would be a nice to have though!
                          Check the attached update :-)
                          Done!
                          Totally overlooked that, thanks! Will need to find out which version that is
                          Attached a version that supports https and contains all images.
                            Thanks for the responses. Keep up the great work!
                            Mark
                            HS3 Pro 3.0.0.534
                              Sorry to ask a dumb question, but how do I tell it to use HTTPS?
                              I turned on HTTP in the synology and tried port 5000. I can log into Surveillance Station with the username/password specified in the config file.
                              When I try it with address set to "DiskStation" and port set to 5000, the device says "Disconnected" and I see the following in the log:
                              May-08 14:42:01 SurveillanceStation URL: http://DiskStation:5000/webapi/query...on=1&query=ALL
                              May-08 14:42:01 SurveillanceStation Error System.Net.WebException: The operation has timed out at System.Net.HttpWebRequest.GetResponse() at Synology.WebRequest.GetUrl(String url, Int32 timeout) at Synology.SynologyBase.Execute(IApiCommand cmd)
                              May-08 14:41:47 Plug-In Finished initializing plug-in SurveillanceStation
                              May-08 14:41:47 SurveillanceStation Completed InitIO
                              May-08 14:41:42 SurveillanceStation Entering InitIO
                              May-08 14:41:42 Info Plugin SurveillanceStation has connected. IP:127.0.0.1:61106
                              May-08 14:41:41 Plug-In Interface SurveillanceStation is running as a trial, 29 days remaining.
                              If I try the string from the log (http://DiskStation:5000/webapi/query.cgi?api=SYNO.API.Info&method=Query&version=1&query=ALL) in IE, I get back a very long string that starts with {"data":{"SYNO.API.Auth":{" . . .
