SurveillanceStation plug-in - Feature requests
This is a sticky topic.
  • SurveillanceStation plug-in - Feature requests
    Please post your feature requests here.
    Will it be possible to set the new Home / Away status in Surveillance Station from the HomeSeer plugin?
      I will look into it. Last time i checked, there was no API documentation available for the latest SS version.
      At the moment I am busy with some construction works at home, so dont expect a new version in the coming weeks...
        Any update on the Home/Away support?
        Sent from my Pixel XL using Tapatalk
          2 step verification would be good
            Hi,
            Last time I checked the API documentation wasn't updated.
            Once I have the necesarry API calls, implementation is easy. I'm afraid I don't have time to debug how the web-based application is working ...
            [EDIT]
            Seems like a new api was released:
            https://global.download.synology.com...b_API_v2.7.pdf
            Give me some time to implement this properly. My agenda is quite full at the moment
            [/EDIT]
              Home/Away
              Very interested in 'home mode' support. I'd like to trigger my cameras to record on motion when we set our alarm system to 'away'.
                Surveillance Station on QNAP
                I currently have 8 cameras network connected to a QNAP TS-453 Pro. I have full time low resolution and motion alerted high resolution recording in place. I would like to be able to integrate some of my SS functionality with my Homeseer capabilities and maybe further extend things by using IFTTT to link actions between Homeseer and my Abode alarm system.
                Do you have any plans of providing support for QNAP?
                  I saw this plugin is called "Surveillance Station" and probably incorrectly assumed it was for QNAP Surveillance Station" A bit more reading seems to show this is for Synology Surveillance Station. I assume this plugin isn't QNAP Surveillance Station compatible then?
                  Nathan
                  HS 3.0.0.435 (PRO)
                  Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
                  Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
                  Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
                  http://www.kazteel.com/
                    AFAIK no it isn't.
                      No, it only works for Synology Surveillance Station.
                      Highest on my prio list is switching to .NET core. Afterwards I'll add the home/away feature. Don't have any timelines though.
                        Originally posted by kriz83 View Post
                        Hi,
                        [EDIT]
                        [/EDIT]
                        Any update on Home/Away mode?
                          Need to do a rewrite so it all works version independent. Hope to have some time during christmas.
                            Available now in version 1.1.0.0
