Fresh Start - Remove all previous camers - UltraNetCam3 plugin 3.0.6423.20219
  • Fresh Start - Remove all previous camers - UltraNetCam3 plugin 3.0.6423.20219
    I have moved from a Raspberry Rpi 2 via a Rpi3 and finally to a SEL and have had several DLink hard wired cameras and several Foscam Wifi cameras.
    Whenever I move from one HS3 device to the next I seem to see several old and unused cameras and some newer Foscam cameras that display the following errors. This only affects wifi cameras.
    Jan-24 15:24:55 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    Jan-24 15:24:43 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    Jan-24 15:24:31 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    Jan-24 15:24:19 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    Jan-24 15:24:07 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    Jan-24 15:23:54 Warning The Snapshot request sent to NetCam006 [Kitchen] failed: A null reference or invalid value was found [GDI+ status: InvalidParameter]
    I now wish to start from a clean sheet and would like to know the folder/file locations and commands to remove ALL traces of old and present cameras.
    Once I have achieved the clean-up I want to install my wired and Foscam Fi9826 cameras.
    Any help most welcome.
    Jo
    Have removed all evets that trigger the cameras.
    Still getting errors every 17 seconds from Foscam cameras. Suspect it may be a network issue.
    Feb-10 15:39:52 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:39:47 Z-Wave Device: Garage Luminance (17) Set to 764 (Lux)
    Feb-10 15:39:35 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:39:18 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:39:01 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:38:44 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:38:27 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:38:10 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:37:53 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:37:36 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:37:19 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:37:02 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:36:46 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:36:29 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:36:14 Z-Wave Device: Bathroom Temperature (TRV) Set to 16.97 (C)
    Feb-10 15:36:12 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:36:08 Z-Wave Device: Bathroom Temperature (TRV) Set to 16.97 (C)
    Feb-10 15:35:55 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:35:43 Z-Wave Device: Basement Loft Temperature Set to 13.26 (C)
    Feb-10 15:35:38 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:35:21 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:35:04 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:34:47 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:34:31 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    Feb-10 15:34:14 Error The Snapshot request sent to NetCam001 [Garage] failed: The operation has timed out.
    I have since connected SEL directly to the LAN eliminating wifi.
    Can someone give me a clue as to what I need to look at and any diagnostics
    Jo
      Update.
      There is an option in the Plug-in camera refresh rate. This option has Disabled and then a range of 2 to 300 seconds.
      In the Disabled option cameras record events without error. If I change this option in the range 2 to 300 seconds the Plug-in will lock up and defeats the purpose of it.
      I can only conclude that the time taken to Request a Snapshot is less than the time to receive the updated snapshot and thus report an error.
      Can anyone shed any light on what to change within the Plug-in or in the network.
      Thanks Jo
