Hi, I'm trying to get UltraNetCam to work with this camera. Based on the spec's, should it work? Been procrastinating on getting it to work and only have 3 days left on my UltraNetCam 30-day trial.
Thanks!
Thanks!
Do you happen to have the URL that displays the camera snapshot? That's typically all that is required to get a camera to work with my plug-in. If you need more trial time, please open a ticket with HomeSeer and ask them to extend your trial another 30 days.
Anyone able to recommend reasonably priced TCP trigger enabled PTZ cameras that work with UltraNetCam? Indoor and Outdoor.
Would love to replace my Foscams that do not support TCP trigger.
I currently use email notifications from the Foscam cameras to trigger events. But that is less than satisfactory since there is a minimum 1 minute lag. HS3 can only check POP email every 1 minute. So combine that with the processing and email transmission lag, in reality it is more than a minute.
Th list on the OP does not tell me which have TCP trigger.
Hello,
Wondering if you were ever able to get an Amcrest IP cam to work with this plugin? I'm considering purchasing but want to make sure they will be supported?
Thank you,
HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events Plugin's:
Any camera that provides a URL that outputs a snapshot directly will work with the plug-in. I no longer use Foscam or Amcrest cameras so I cannot confirm.
I am trying to configure new cams to my plugin but when creating or trying to edit the "NetCam Videostream Path:" filed, it is lock and I can't change the path.
