UltraNetCam Controls - New Feature
This is a sticky topic.
  • UltraNetCam Controls - New Feature
    UltraNetCam HSPI version 1.1.4781.25469 adds the ability to define NetCam Controls to control your NetCam using HomeSeer device actions.
    Feel free to post import files for other NetCams so others don't have to manually type them in.
    Importing File Format
    When importing Controls into UltraNetCam HSPI, please using the following file format:
    [Control Name] /path-to-action.extenstion?parm1=value1&parm2=value2
    Example
    # Comment
    [Move Up - Start] /decoder_control.cgi?command=0
    [Move Up - Stop] /decoder_control.cgi?command=1
    [Move Down - Start] /decoder_control.cgi?command=2
    [Move Down - Stop] /decoder_control.cgi?command=3
    [Move Left - Start] /decoder_control.cgi?command=4
    [Move Left - Stop] /decoder_control.cgi?command=5
    [Move Right - Start] /decoder_control.cgi?command=6
    [Move Right - Stop] /decoder_control.cgi?command=7
    If your camera only supports authentication by passing the user name and password attached to the query string, then use the following placeholders in the query string:
    $user will be replaced with the user defined for the NetCam device.
    $pass will be replaced with the password defined for the NetCam device.
    Example
    [Some Control Command] /decoder_control.cgi?command=0&usr=$user&pwd=$pass
    Ultrajones
    [Screenshot]
    Screenshots
      Foscam Import Files
      This is the Foscam JPEG import file. It should work with the Foscam JPEG Cameras. Feel free to modify the import file and remove commands you won't be using.
        Has anyone per chance created a Control file for Amcrest camera's? Mike
        Computer: CUK Intel NUC7i7BNH
        Op System: Windows 10 Pro - Work Station
        HS Version: HS3 Pro Edition 3.0.0.435
        Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
