Hi.
I've been using HS2 for a little while now. I use WebcamXP (well actually Webcam7 but it works the same as XP) for my surveillance cameras.
WebcamXP streams video but all cameras setup appear in one stream.
I have SageWebcamXP plugin and interface that allows me to 'capture' detected motion and thereby run events. This setup works well for what I want.
I hope to upgrade to HS3 but apparently Sage are not supporting HS3 with their plugins.
I have looked at, and tried, UltraNetCam on HS3 and can set up my IP cameras. The problem I face is I have two analogue hard wired cameras feeding into USB adapters. I can capture these in WebcamXP but can't seem to see a way to capture them in UltraNetCam.
So - a two part question, can non IP cameras feed into the plugin, or is there a way to capture the stream from WebcamXP?
Cheers
Cheers
