UltraNetCam3: server error in "/" application
  • UltraNetCam3: server error in "/" application
    Trial copy of UltraNetCam3 plugin, HS3 .147 on Win 7 and Win 8.1
    UltraNetCam3 installs but won't run: server error in '/' application.
    The Configuration Error message apparently tries to give me some suggestions, but they are not helpful:
    In Web.Config : line 111 is exactly as supposed to be: <add assembly="*"></add>
    I cannot make sense of the rest of the configuration error information
    Any suggestions?
    Remark 1: I could never run this plug in in HS2, similar problems.
    Remark 2 : tried running on 4 different computers Win7/Win8.1 (trial versions of HS3): exactly the same error
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: Could not load file or assembly 'HomeSeerAPI (2)' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Source Error:
    Line 109: <add assembly="System.Web.DynamicData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> Line 110: <add assembly="System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> Line 111: <add assembly="*"> </add>Line 112: Line 113: <buildproviders>
    Source File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\web.con fig Line: 111
    Assembly Load Trace: The following information can be helpful to determine why the assembly 'HomeSeerAPI (2)' could not be loaded.
    === Pre-bind state information === LOG: DisplayName = HomeSeerAPI (2) (Partial) WRN: Partial binding information was supplied for an assembly: WRN: Assembly Name: HomeSeerAPI (2) | Domain ID: 15 WRN: A partial bind occurs when only part of the assembly display name is provided. WRN: This might result in the binder loading an incorrect assembly. WRN: It is recommended to provide a fully specified textual identity for the assembly, WRN: that consists of the simple name, version, culture, and public key token. WRN: See whitepaper http://go.microsoft.com/fwlink/?LinkId=109270 for more information and common solutions to this issue. LOG: Appbase = file:///C:/Program Files/HomeSeer HS3/html/ LOG: Initial PrivatePath = C:\Program Files\HomeSeer HS3\html\bin Calling assembly : System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a. === LOG: This bind starts in default load context. LOG: Using application configuration file: C:\Program Files\HomeSeer HS3\html\web.config LOG: Using host configuration file: LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine .config. LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Attempting download of new URL file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/Temporary ASP.NET Files/root/29b23a33/6826ea6b/HomeSeerAPI (2).DLL. LOG: Attempting download of new URL file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/Temporary ASP.NET Files/root/29b23a33/6826ea6b/HomeSeerAPI (2)/HomeSeerAPI (2).DLL. LOG: Attempting download of new URL file:///C:/Program Files/HomeSeer HS3/html/bin/HomeSeerAPI (2).DLL. WRN: Comparing the assembly name resulted in the mismatch: NAME ERR: Failed to complete setup of assembly (hr = 0x80131040). Probing terminated. </buildproviders></add></add>
    The error appears to be some type of Microsoft .Net framework issue on your system. You can attempt to run a .Net repair, or simply wait for the updated UltraNetCam3 HSPI that will be released soon.
    I started the configuration of UltraNetCam3 HSPI to convert the ASPX web pages to use HomeSeer jQuery controls instead. I hope to have this complete within the next 14 days. Once released, you can ask HomeSeer to reset your trial for another 30 days.
    Ultrajones
      Tnx, I'll wait for your next version.
        Edited 8 december: solved (more or less), see my next post
        I updated to 3.0.5437.34440, same error message.
        Tried MS .Net repair, no change.
        I also tried installing HS3 + UltraNetcam3 on a newly installed computer with latest Win8.1 updates and clean .Net :same result. .Net cannot be broken, nothing else is using it.
        I now have 4 computers with either Win7 or Win8.1 , all giving the same error.
        Any more ideas?
          I finally got UltraNetCam3 working, but only on a trial copy of HS3!
          - downloaded HS3 .147
          - on all previous attempts I immediately changed to my working HomeSeer.hds configuration. Now I started with an empty .hsd file, and first installed UltraNetcam3 plugin. This works!
          I then added all my other plugins (X10 X15 RFXCOM Netcam, HSTouchserver), everything still works ok.
          Unfortunately these are now all trial, I still cannot find a way to get UltraNetcam3 working on my registered copy of HS3. Any suggestions?
          (To me it seems the error messages complaining about .Net are just nonsense.
            Please download UltraNetCam3 HSPI version 3.0.5463.32569. It has been completely redesigned to use HomeSeer jQuery controls instead of ASPX.Net.
            Ultrajones
              tnx a lot, tested in Win7 and Ubuntu, works fine!
