Trial copy of UltraNetCam3 plugin, HS3 .147 on Win 7 and Win 8.1
UltraNetCam3 installs but won't run: server error in '/' application.
The Configuration Error message apparently tries to give me some suggestions, but they are not helpful:
In Web.Config : line 111 is exactly as supposed to be: <add assembly="*"></add>
I cannot make sense of the rest of the configuration error information
Any suggestions?
Remark 1: I could never run this plug in in HS2, similar problems.
Remark 2 : tried running on 4 different computers Win7/Win8.1 (trial versions of HS3): exactly the same error
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Could not load file or assembly 'HomeSeerAPI (2)' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Source Error:
Line 109: <add assembly="System.Web.DynamicData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> Line 110: <add assembly="System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"> Line 111: <add assembly="*"> </add>Line 112: Line 113: <buildproviders>
Source File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\web.con fig Line: 111
Assembly Load Trace: The following information can be helpful to determine why the assembly 'HomeSeerAPI (2)' could not be loaded.
=== Pre-bind state information === LOG: DisplayName = HomeSeerAPI (2) (Partial) WRN: Partial binding information was supplied for an assembly: WRN: Assembly Name: HomeSeerAPI (2) | Domain ID: 15 WRN: A partial bind occurs when only part of the assembly display name is provided. WRN: This might result in the binder loading an incorrect assembly. WRN: It is recommended to provide a fully specified textual identity for the assembly, WRN: that consists of the simple name, version, culture, and public key token. WRN: See whitepaper http://go.microsoft.com/fwlink/?LinkId=109270 for more information and common solutions to this issue. LOG: Appbase = file:///C:/Program Files/HomeSeer HS3/html/ LOG: Initial PrivatePath = C:\Program Files\HomeSeer HS3\html\bin Calling assembly : System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a. === LOG: This bind starts in default load context. LOG: Using application configuration file: C:\Program Files\HomeSeer HS3\html\web.config LOG: Using host configuration file: LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine .config. LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Attempting download of new URL file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/Temporary ASP.NET Files/root/29b23a33/6826ea6b/HomeSeerAPI (2).DLL. LOG: Attempting download of new URL file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/Temporary ASP.NET Files/root/29b23a33/6826ea6b/HomeSeerAPI (2)/HomeSeerAPI (2).DLL. LOG: Attempting download of new URL file:///C:/Program Files/HomeSeer HS3/html/bin/HomeSeerAPI (2).DLL. WRN: Comparing the assembly name resulted in the mismatch: NAME ERR: Failed to complete setup of assembly (hr = 0x80131040). Probing terminated. </buildproviders></add></add>
Any suggestions?
Configuration Error
Source Error:
