Error when using motion alarm trigger
  • Error when using motion alarm trigger
    I'm trying to setup a motion alarm trigger for a Grandstream GXV3610v2. This camera supports sending a HTTP request when a motion is detected, same as Foscam cameras.
    I first tried this with the camera and I can see that trigger arrives at the HS3 server. The HS3 logs shows these two lines when the first call comes in.
    Jan-30 7:03:42 PM Startup ASP.NET application host created
    Jan-30 7:03:40 PM Startup Creating ASP.NET application host...
    But nothing is triggered (I've setup the UltraNetCam motion trigger event).
    So instead of using the camera, I manually entered the UltraNetCam trigger URL
    /hspi_ultranetcam3/hspi_ultranetcam3.aspx?trigger=alarm
    into my browser (this should be the same what the camera is doing). I'm getting the same ASP.NET log entries as before, but now I can see the following error in the browser. This looks like either a bug or a misconfiguration to me.
    I'm using a Zee-S2, with the latest SW version.
    [ATTACH]51749[/ATTACH]
    Hello Mike,
    Where did you find those instructions? They are old. Please check the UltraNetCam3 HSPI User's Guide under Help.
    If I recall correct, you'll use:
    http://ip_address_of_homeseer/UltraNetCam3?trigger=alarm
    Ultrajones
      Thanks UJ, for the quick reply. Not sure where I go the older help file from, but I found the new one.
      I used the URL from the new help (it's the same you already posted server/UltraNetCam3?trigger=alarm ) and now I get the expected OK in the browser window (no error anymore).
      Also the camera trigger works now, at least from the browser (I created a pseudo camera with my laptop's IP to test that). Need to test the camera tomorrow, but I don't see why this shouldn't work either.
