Protocol Violation some panasonic BLC Cameras
  • Protocol Violation some panasonic BLC Cameras
    Getting this error on some of my cameras
    2/26/2016 3:17:00 PM...Error~~!~~The Snapshot request sent to NetCam001 [office] failed: The server committed a protocol violation. Section=ResponseHeader Detail=CR must be followed by LF
    Is there a solution?
    THANX
    MITCH
    If I had a son he would be a son of a Mitch
    I have no idea why it would be failing. What type of cameras are they? Are they running the latest firmware from the vendor?
    Ultrajones
      it is an older Panasonic bl-c10 with the latest firmware
        Try this:
        1) Shutdown HomeSeer
        2) Download the attached file and remove the .txt extension. The file name should be HSPI_ULTRANETCAM3.exe.config
        3) Put the file into the HomeSeer root directory (replacing the existing file).
        4) Restart HomeSeer
        This config file adds:
        PHP Code:
            <system.net
        settings
        httpWebRequest useUnsafeHeaderParsing="true" />
        settings
        system.net
        Ultrajones
          Thaat Worked
          That solved the issue.... is there a downside to the switch you changed
          THANX
          MITCH
