Error from Log
  • Error from Log
    Hi,
    Trying to have UltraNetCam generate a snapshot based on a ELM M1 output change and I'm seeing this error in the log:
    Dec-02 5:03:37 PM 1 Error System.ArgumentException: Insufficient Space Parameter name: bytes at System.Text.UTF8Encoding.InternalGetBytes (System.Char* chars, Int32 count, System.Byte* bytes, Int32 bcount, System.Text.EncoderFallback fallback, System.Text.EncoderFallbackBuffer& buffer, System.Char& leftOver, Boolean flush) [0x00000] in :0 at System.Text.UTF8Encoding.InternalGetBytes (System.Char[] chars, Int32 charIndex, Int32 charCount, System.Byte[] bytes, Int32 byteIndex, System.Text.EncoderFallback fallback, System.Text.EncoderFallbackBuffer& buffer, System.Char& leftOver, Boolean flush) [0x00000] in :0 at System.Text.UTF8Encoding.GetBytes (System.Char[] chars, Int32 charIndex, Int32 charCount, System.Byte[] bytes, Int32 byteIndex) [0x00000] in :0 at Microsoft.VisualBasic.Strings.Asc (Char String) [0x00000] in :0 at Microsoft.VisualBasic.Strings.Asc (System.String String) [0x00000] in :0 at HSPI_ULTRAM1G3.hspi_plugin.VerifyChecksum (System.String strLen, System.String strData, System.String strCRC) [0x00000] in :0 at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived (System.String strDataRec) [0x00000] in :0
    I'm seeing the snapshot in latest snapshot images but email is not being generated.
    Any help would be welcome!
    Wow, that's an interesting error. What exactly are you doing that is causing that error? I would like to try to duplicate it. Please provide screenshots if possible.
    Ultrajones
