Motion trigger
    Motion trigger
    Is there a tutorial for setting up curl? I have it set up system wide but when it try to run "curl --request GET https://ip-addressort/UltraSighthoundVideo3?rule=1" in command prompt it doesn't do anything it just hangs. What am I doing wrong?
    First thing I see is you have specified https. Is HomeSeer setup to accept https connections? If not, change it to http. This will also require a change to the port.
    Second thing, depending on your config, it could be that HomeSeer is wanting some authentication. Try adding username and password in the url like this:
    curl --request GET https://username:password@ip-address:port/UltraSighthoundVideo3?rule=1
    Of course, all of this assumes you've got the correct HomeSeer IP address and port
      That was the problem i figured since https is what the trigger said to use it was correct but changing it to http fixes it. Thanks
