Problem with two digit motion trigger rules
  • Problem with two digit motion trigger rules
    Hello, Ultra. I think I may have uncovered a bug in the plugin last night...
    I've been successfully using several events with trigger "Sighthound Video Motion Trigger" for a while now with no problems. But last night I added two new Sighthound motion trigger events, using two digit rules for the first time, and right away I noticed something not right because the wrong events started triggering unexpectedly.
    After some testing, I've discovered that it appears the plugin is truncating the second digit. So, for example, if I send "curl --request GET http://ipaddress/UltraSighthoundVideo3?rule=12" from Sighthound, HS3 actually runs events that have a trigger of "Motion Trigger rule number 1" (instead of "Motion Trigger rule number 12"). If I send "curl --request GET http://ipaddress/UltraSighthoundVideo3?rule=23" from Sighthound, events with "Motion Trigger rule number 2" trigger run.
    Could you please test this on your end?
    Hello teladog01,
    I have not been able to look into this yet. This is on my todo list for this week. Sorry for the delay.
      The issue you reported is a confirmed bug. I will post an update that will fix the issue within the hour.
      Ultrajones
        Ultrajones
        The update appears to have fixed it for me. Thanks, Ultrajones
