What HS4 plug-ins would you like to see and (what) would you pay for them.
  • #31
    BTW...what I want ...as an example.
    Have a BT5.0 USB dongle in my car that can have a line of site range of 1 mile (output power is adjustable - i have several) and for it to be detected by a BT USB dongle on my HS4 server. I glanced around and it looks like Jon000 doesn't work that way (w/ usb dongles). Even the microsoft store has apps that can track BT devices in / out range db/loss via a usb BT, so I know the data is there, I just have no way to get it into HS4.
    • #32
      It does work, but only if the dongle works with Windows default bluetooth stack, not drivers which come with the dongle
      • #33
        A plugin that functions like Z-Seer? Constantly testing the z-wave nodes and if one drops off you can have it text you or something, if more than a few drop off, it can restart the z-wave controller. My zwave network goes down occasionally, and I have to power cycle the z-net and everything starts working again.
        I wish we had something to program the addressable leds, and make simple flow and scanner patterns. Maybe this could take over landscape lighting. Maybe there's a lighting controller out there that just needs a plugin.
        What the heck is Node Red? Can i use that to program ESP32s? I failed at learning to program my esp boards. If anybody's good at programming ESPs, I'll send you my boards for programming $$$..
        • #34
          Check out the SDJ-Health PI, it should allow you to do exactly what you want.
          Enabled Plug-Ins:
          • #35
            enigmatheatre...inquired directly to Jon000. This will only support up to BT3.0...and the BLE+range won't be there. Thanks anyway! I must be the only one using HS3/4 that has issues with stable geofencing.
            • #36
              A plugin that will support, interrogate and change settings on the new Sony Android LED and OLED TV. Like the LBDenon plugin.
              • #37
                George have you tried the mediacontroller PI? It supports Sony TVs, not sure your version, but try it.
                • #38
                  Hadn't thought about it. I'll give it a go.
                  My Sony is the latest 77" OLED model with the new Android upgrades.
                  • #39
                    Rheem EcoNet Water Heater has a few requests. And today a link was provided to the API. I would go with the (apparently) common $30-40 USD range.
                    Karl S
                    HS3Pro on Windows 10
                    96 Devices
                    54 Z-Wave Nodes
                    37 Events
                    Google Home: 3 Mini units
