Master Device creation in C#
    I'm trying to put together my first plugin and I'm not able to find any examples of how to create the master device. Does anyone have a code snippet that they could share?
    Sent from my SM-G988U using Tapatalk
    Have a look at the sample plugin https://github.com/HomeSeer
    Scripts =
    Various
      That's where I started to work from. I've gathered a few good thoughts from that, but I think I'm confused. This is what I have so far:
      DeviceFactory df = DeviceFactory.CreateDevice(Id);
      Console.WriteLine("Id: Step 1" + Id);
      df.WithName("ZoneMinder Main");
      df.AsType(EDeviceType.Generic,0);
      var ff = FeatureFactory.CreateFeature(Id);
      ff.WithName("Server Load");
      df.WithFeature(ff);
      df.PrepareForHs();
      What am I missing?
        ref = HS.CreateDevice(df)
        -- Wim
          Thanks Gents!
            Hi lorenjz,
            Not saying this is perfect or the best way but here you go:
            Sub Build_Device()
            Dim deviceinfo As HsDevice = Nothing
            If HomeSeerSystem.GetDeviceByAddress(Name & "ROOT") Is Nothing Then
            Try
            Dim newdevice As New DeviceFactory
            Dim PIED As PlugExtraData = New PlugExtraData()
            Dim hsFlags As EMiscFlag() = New EMiscFlag() {EMiscFlag.ShowValues}
            newdevice = DeviceFactory.CreateDevice(Id)
            newdevice.WithLocation(Name)
            newdevice.WithLocation2(Name)
            newdevice.AsType(EDeviceType.Generic, 0)
            newdevice.WithName(hydrawise.data.controller.name)
            newdevice.WithMiscFlags(hsFlags)
            Dim ndd As NewDeviceData = newdevice.PrepareForHs()
            Dim device As Integer = HomeSeerSystem.CreateDevice(ndd)
            Dim adddata As New Dictionary(Of EProperty, Object)
            adddata.Add(EProperty.Address, Name & "ROOT")
            HomeSeerSystem.UpdateDeviceByRef(device, adddata)
            deviceinfo = HomeSeerSystem.GetDeviceByRef(device)
            HomeSeerSystem.WriteLog(ELogType.Info, "New Device " & deviceinfo.Name & " (" & deviceinfo.Ref & "-" & deviceinfo.Address & ") has been created", Name)
            Catch ex As Exception
            HomeSeerSystem.WriteLog(ELogType.Error, "Unable to crete device: " & ex.Message, Name)
            End Try
            Else
            deviceinfo = HomeSeerSystem.GetDeviceByAddress(Name & "ROOT")
            HomeSeerSystem.WriteLog(ELogType.Debug, "Not creating device (" & deviceinfo.Name & ") as it already exists", Name)
            End If
            End Sub
              Hi lorenjz,
              And then for adding features to the device
              (Note - I use a loop to add the features hence I've structure my code this way! I run the loop from the Device creation sub hence HS device as an input parameter which allows me to connect the feature to the correct parent)
              Sub Check_Feature_Build(parent As HsDevice)
              Dim featureinfo As HsFeature = Nothing
              If HomeSeerSystem.GetFeatureByAddress(Name & "Status") Is Nothing Then
              Try
              Dim newfeature As New FeatureFactory
              newfeature = FeatureFactory.CreateFeature(Id)
              newfeature.OnDevice(parent.Ref)
              newfeature.AsType(EFeatureType.Generic, 0)
              newfeature.WithName("Status")
              newfeature.WithLocation(Name)
              newfeature.WithLocation2(Name)
              newfeature.WithDefaultValue(0)
              newfeature.AddGraphicForValue("/folder/imageA.png", 0, "Status Text")
              newfeature.AddGraphicForValue("/folder/imageB.png", 1, "Status Text")
              newfeature.WithMiscFlags(hsFlags)
              Dim nfd As NewFeatureData = newfeature.PrepareForHs()
              Dim feature As Integer = HomeSeerSystem.CreateFeatureForDevice(nfd)
              adddata.Add(EProperty.Address, Name & "Status")
              HomeSeerSystem.UpdateFeatureByRef(feature, adddata)
              featureinfo = HomeSeerSystem.GetFeatureByRef(feature)
              Console.WriteLine("Feature ID: " & feature & " (Name: " & featureinfo.Name & " - Device Type: " & featureinfo.TypeInfo.Type.ToString() & "-" & featureinfo.TypeInfo.SubType.ToString() & ")")
              HomeSeerSystem.WriteLog(ELogType.Info, "New Feature " & featureinfo.Name & " (" & featureinfo.Ref & "-" & featureinfo.Address & ") has been added to " & parent.Name & "(" & parent.Ref & ")", Name)
              HomeSeerSystem.WriteLog(ELogType.Error, "Unable to crete device feature: " & ex.Message, Name)
              End Try
              Else
              featureinfo = HomeSeerSystem.GetFeatureByAddress(Name & "Status")
              HomeSeerSystem.WriteLog(ELogType.Debug, "Not creating device feature (" & featureinfo.Name & ") as it already exists", Name)
              End If
              End Sub
                So , will we see new plugins made by you soon
                lorenjz russr999
                  lorenjz russr999
                  I have the Hydrawise HS4 Plugin done! So building out the HS3 version to release together! 😁
                  (For any new plugins, ideally I think people should be able to get HS3 and/or HS4 version without having to pay more! Just my view though hence releasing together!)
                  I already have a HS3 plugin in the store - rnbPlace which is Homeseers control and status of myPlace by Advantage Air
                    lorenjz russr999
                    Could be.... Experimenting with Zoneminder. First I have to figure out how to parse two bits of JSON data from zoneminder to features. Once that's done there are a couple of other bits.
                      I think that I'm starting to understand. However, it's not clear how the features get their functionality. For instance when a button is clicked, should there be an event-listener enabled or what method is called to have it do something?
                      Thanks again for all of the help!
                        From memory, this is the sub where I capture the buttons action where the button is on the devices page:
                        Public Overrides Sub SetIOMulti(colSend As List(Of ControlEvent))
                        If the button is on a feature page then you will need to use an ajax postback
                          But your plugin is done with VB correct?
                            Yes
                            If you're using C#, the equivalent is:
                            public override void SetIOMulti(List<ControlEvent> colSend)
                              Yes
                              Perfect! Thank you
