Need help with SpeakerClient syntax
    I am not a C programmer, but trying to convert SpeakerClient.cs to an equivalent SpeakerClient.vb I am having the following issue that I cannot seem to work out.
    Here is the cs code:
    class SpeakerClient : IFromSpeaker
    private ISpeechAPI _speakHost;
    private IScsServiceClient<ISpeechAPI> _client;
    private const int SPEAKER_INTERFACE_VERSION = 10; // 10=first version for HS3 with new WCF like API
    private string _clientName = "";
    public static object objlock = new object();
    public SpeakerClient(string name)
    _clientName = name;
    public bool Connect(string username, string password)
    lock (objlock)
    string ipAddress = "127.0.0.1";
    Logger.LogInfo("Connecting speaker client {0} to HomeSeer IP {1}", _clientName, ipAddress);
    try
    _client = ScsServiceClientBuilder.CreateClient<ISpeechAPI>(new ScsTcpEndPoint(ipAddress, 10401), this);
    _client.Disconnected += new EventHandler(ClientDisconnected);
    _client.Connected += new EventHandler(ClientConnected);
    catch (Exception e)
    and here is the VB code I am having trouble with the statements highlighted in red showing as errors:
    Public Sub Connect(ByVal username As String, ByVal password As String)
    Dim ipAddress As String = "127.0.0.1"
    Lock(objlock)
    OutputHSLog(LOG_INFO, "Connecting speaker client " & _clientName & " to HomeSeer IP " & ipAddress)
    Try
    _client = ScsServiceClientBuilder.CreateClient(Of ISpeechAPI)(New ScsTcpEndPoint(ipAddress, 10401))
    _client.Disconnected += New EventHandler(ClientDisconnected)
    _client.Connected += New EventHandler(ClientConnected)
    Catch ex As Exception
    What am I doing wrong?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
    What's the error?
      Public Class test
          Public Event MyEvent(sender As Object, e As EventArgs)
          Private Sub foo()
              Dim myobj As New test()
              AddHandler myobj.MyEvent, AddressOf ehh
          End Sub
          Private Sub ehh(sender As Object, e As EventArgs)
          ' do something
          End Sub
      End Class
        It's telling me that I must use RaiseEvent, but I don't know the sintax. Please see attached CS file. This is what I'm trying to convert to an equal VB file.
        -Larry
        Plugins:
        Hardware:
          You don't need to RaiseEvent - this will be called by IScsServiceClient.
          Your code is client - so you need to receive the event - which is done by AddHandler.
          So when your client connects/disconnects - your handler will be called to inform you.
          So you just need
          AddHandler _client.Connected, AddressOf ClientConnected
          Private Sub ClientConnected(sender As Object, e As EventArgs)
          ' do something
          End Sub
            Thank you that makes it more clear.
            -Larry
            Plugins:
            Hardware:
